  Soarer Central * General Soarer Chat * Soarer after a bit of spit and polish Previous Previous    Next Next
Ali Saeed
Friday, April 01, 2011 - 09:28 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its been a while since i posted some pictures of my car and it was a decent day to give the car a bit of a wash and polish:
Ali Saeed
Friday, April 01, 2011 - 09:30 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
shes sitting a bit higher than normal as i had to go to uni, which has ridiculously high speed bumps. anyway used meguiars glass cleaner to clean the class and it looks epic!
polish the headlights too:
Ali Saeed
Friday, April 01, 2011 - 09:33 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the bad stuff:
sister backed into drivers door and front bar two weeks apart :-( also looks like mum has been opening the door on my passenger quarter panel too :-(
and lots of stress cracks on the front bar which will be replaced when the custom bar group buy comes through :-)
and one shot of the interior
Matt Sartori
Rx7
Reg: 08-2008
Saturday, April 02, 2011 - 12:06 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Women shouldn't be allowed to drive.
Ali Saeed
Saturday, April 02, 2011 - 03:25 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my thoughts exactly.
Warren Moore
JZZ31 2JZGTE swap
Reg: 01-2010
Saturday, April 02, 2011 - 10:18 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
women should be allowed out of the kitchen, if they manage a way out, you need to invest in a bigger ball and chain
Sunday, April 03, 2011 - 07:57 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Forget the women , GET some LARGER exhaust tips for gods sake ... LOL . Looks like throwing a small c0ck down a hookers hallway !!! DOesnt even touch 1 side at a time , hehehe .
Monday, April 04, 2011 - 06:05 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wouldn't look as bad if they were level with the edge of the rear bar.
David Grima
1JZ-GTE TT
Reg: 07-2007
Monday, April 04, 2011 - 02:43 pm, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
definitely need a decent sized exhaust bro, mine was like that when I first fitted my kit and looked SH!T with the stock exhaust lol
Ali Saeed
Monday, April 04, 2011 - 04:10 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i havent spent much money on the car in the last year so i still havent done the exhaust, i will get around to it eventually.
Anika Le
TT 1JZ-GTE
Reg: 01-2009
Monday, April 11, 2011 - 04:07 pm, by:  Anika Le (Hime1901) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt Sartori wrote on Saturday, April 02, 2011 - 12:06 pm:
I beg to differ. Some of us are good drivers - like moi!
Matt Sartori
Rx7
Reg: 08-2008
Monday, April 11, 2011 - 05:00 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Asian AND Female?
Everyone get off the road!
Okay ill stop now >_>
