  Soarer Central * General Soarer Chat * Dyno Previous Previous    Next Next
Justin Richardson
tasmania
Sunday, April 17, 2011 - 08:53 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
had my old soarer on the dyno last week at wolf it made 268rwkw but it made 908nm and it has the wolf working the auto
Jason Cheah
2JZGTE JZZ31
Monday, April 18, 2011 - 04:47 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That is massive. Awesome.
Monday, April 18, 2011 - 10:03 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Never believe Torque readings form a Dyno as they only measure tractive effort .
The only true way to work out Torque is on an engine dyno .
Otherwise , pretty stout @ rwkw though :-) Very nice
Justin Richardson
tasmania
Monday, April 18, 2011 - 10:12 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its got lots left in it yet we didnt wont to push it to fare as the new onwer had to drive it from vic to qlds
Warren Moore
JZZ31 2JZGTE swap
Reg: 01-2010
Monday, April 18, 2011 - 11:28 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
are you not happy with that torque reading? it seems about right. guys with supra's with stock twins 280-300rwkw are making 850-1000nm
Justin Richardson
tasmania
Monday, April 18, 2011 - 11:36 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah buts that only at 5500 rpms too
Ali Saeed
Monday, April 18, 2011 - 11:38 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how are these engines making so much torque when:
Ferrari 458 Italia - 420 kW; 540 Nm
Mercedes SLS - Torque: 420kW; 650 Nm
Ali Saeed
Monday, April 18, 2011 - 11:40 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sl65 amg(most powerful mercedes) just puts out over a 1000nm
Warren Moore
JZZ31 2JZGTE swap
Reg: 01-2010
Monday, April 18, 2011 - 11:43 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
duno ey. stock 2jz-gte puts out 450nm
Tuesday, April 19, 2011 - 07:26 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Like i said , You will not get a proper torque reading from a dyno session . Only tractive efforts .
ALi , however , you cannot compare the torque outputs of NA cars to forced induction cars .
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Tuesday, April 19, 2011 - 07:45 am, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Agreed. My Soarer put out about 350nm on a DD dyno. If it was on a Mainline it would probably be significantly higher.
Good numbers by the way Justin.
Cheers.
Aaron Mead
Tuesday, April 19, 2011 - 07:51 am, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ali, thats a flywheel torque measurement for the big benz. The torque measurements postef for the
soarer@900nm is measured after being multiplied by the diff/trans and is measured at the wheels as 'tractive effort'.
Think about what toyota gearboxes/transmissions are capable of transferring 1000nm to the tyres......none!
Bear in mind that, on dyno dynamics dynos at least, you can convert the tractive effort into a pretty accurate flywheel torque reading as well, and have it on the printout instead of tractive effort. My chipped 1uz made 355nm which is not far off the 1990 factory.
The big benz even has its torque restricted to protect the trsnsmission, as the engine is just too powerful!!
Andrew Duaso
311rwkw+++ more soon
Reg: 02-2009
Tuesday, April 19, 2011 - 10:04 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dd dynos are for holden owners cos you can easily tickle them to make more power
my car has been on both and made more on the dd than the mainline, i prefer the mainline printouts much better though, and it shows tractive effort and calculated flywheel nm on the same sheet, yet still its just that calculated not actual or even close, things like tyre size diff ratio have a big influence on this, i put on 19's and make 50nm more at almost the same power compared to the 20's at the same rolling diameter... rwkw is all crap anyway and not relative, my car makes much less than some charged 8's yet many more mph on the 1/4, different power delivery for a car thats the same weight and has same gearing and basically the same car different engine
Aaron Mead
Wednesday, April 20, 2011 - 06:46 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dd/mainline/dynapack, it doesn't matter.
They're just tuning tools.
Wednesday, April 20, 2011 - 07:29 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Agreed Aaron ... Doing the cals on my car on the Moroso calc , for the weight of it and its ET and MPH its making 276rwkw . Best it made on a Dyno was 260 .
