Hey guys. After searching around today. I found no where stocks 1jz timing belts.one place, i think it was supercheap, told my missus that i need a turbo timing belt and they are different because it tells the turbos when to kick in. WOW. What a tool. Does anyone know any shops that keep the timing belt and waterpump in stock??
Friday, July 08, 2011 - 08:15 pm, by: Matchy Loi(Ftk148)
If you give them a part number to a Toyota parts shop, they will order it. Usually takes a day or two to get in. I've never been able to get anything instantly from toyota other than oil filter and fluids.
But no sorry, I can't say where you could get this weekend. Put a wtb, someone might have one laying around.
You could also check the supra forums because i'm pretty sure some of them are same.
The tool I was talking about holds the main pulley still so you can undo/tighten the crank bolt. Otherwise all you would do is turn the crank when you try to undo/tighten the crank bolt. You'd also need a pulley removal tool.
