  Soarer Central * General Soarer Chat * Took Soarer to RAC Track day today Previous Previous    Next Next
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Sunday, July 24, 2011 - 11:41 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So just had a track day today with my Soarer. Drives beautifully, loud as a mudaphaha (we were tracking next to detuned V8 Supercars and my noise could compare ho ho ho).
Two major complaints:
This thing is a LAND BEAST, throwing all that weight around is so tiring.
And being a rear wheel car, i am understeering a LOT. I just can't seem to get my tail out around corners.
Now good chance this is all because im not driving right, still used to whipping around 1.2kkg S chassis. Friend suggested a thicker rear sway bar to stiffen it up a bit.
But yes first time proper experience with a soarer, bit disappointed in the corners but still very fun to drive.
Ali Saeed
Monday, July 25, 2011 - 12:05 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh they arent very tail happy with stock sway bars. Supra swaybars or whiteline swaybars should be good. ive heard TRD supra swaybars were very good.
PS: i saw your car in a picture of one of my mates pictures. He took his 350Z there.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 12:52 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hahaha oooh no way the black one? Tell him he needs to stop spinning the wheels at launch hahaha
Shane Haverkamp
soarer TT
Reg: 10-2007
Monday, July 25, 2011 - 06:38 am, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
do supra sway bars fit ali
and yang was car auto or manual?
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Monday, July 25, 2011 - 08:42 am, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I assume your beast still has air bags, did you use a short to harden up the ride? This can help a bit.
Like you said technique may also be a factor, particularly with vehicle balance and brake usage into the corner, i.e. Are you off the brakes completely when you turn in or are you still trailing off the brakes during this time?
The main thing is you got out and had some fun.
It's good to see you get out and have a go, should be more of it :-)
Jerzy Stopczynski
Westarn Australia
jzz20
Reg: 12-2006
Monday, July 25, 2011 - 09:57 am, by:  Jerzy Stopczynski (Stomps) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good to see more z30 owners having a crack at khanas.. unfortunately it does take quite a bit of work to get them handling properly..
IMO- swaybars are a must... i wouldnt mess around with Supra ones etc.. not when you can get a pair of whitelines for $450 ish..
Swaybars are the best bang for buck upgrade you can do.. cheap and fitting is easy as.. should be able to fit fronts and rears in 30 mins..
i would also fark the airbags off and invest in a decent set of coilies.. but each to their own..
are you coming down to the one is September? im gonna try rebuild my box before then and get back out there..
Stomps
Dave Rose
wa
uzz31 v8
Monday, July 25, 2011 - 11:07 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Keep the air bags and use the track day jumper short ,thats what its for!!!!
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 11:10 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Shane Yeah have seen that supra sways easily fit. And my car is a W58 manual converted. FUN at launch =D
@Nathan Most of the time I'm off the brakes before the turn and am on the accel. I think one of the problems is that my rear tires have got some decent grip where as the fronts are cheapy china tires. I accel out of a corner and it just understeers like mad.
@Jerzy Yeah looks like gonna have to find me a set of whitelines. Recommend just rears or both? And the airbag suspension, i still plan to keep this as a comfortable daily so im pretty inclined to keep the airbags lol.
Hmm september I might be a bit strapped for cash but will see. Definitely want to get more experience taming that land beast.
Dave Rose
wa
uzz31 v8
Monday, July 25, 2011 - 02:45 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So i take it you had the jumper lead on ? that would have been a hard ride?
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 03:24 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
jumper lead? not sure what that is. I had height set to fairly low and TEMs on?
Dave Rose
wa
uzz31 v8
Monday, July 25, 2011 - 04:03 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/67/31585.html?1134295910
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 04:30 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow did not know about that at all...Damn it ah well next time lol
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 05:40 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh and first time experience with ABS....It is like someone repeatedly punching my feat. I don't like the feeling it gives me while driving....
David Grima
1JZ-GTE TT
Reg: 07-2007
Monday, July 25, 2011 - 05:47 pm, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
got any pics or vids?
Dave Rose
wa
uzz31 v8
Monday, July 25, 2011 - 05:49 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did you have traction control on?
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 06:00 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@David Friend took all the pics and videos, just waiting editing and uploading. Will link them once i get
@Dave I don't know...hahaha I could spin the rears fine at launch and keep em spinning up to shifting to second so i just assumed they were off..For future reference though, wheres the switch for traction control?
LOVE launching the V8, spins so easily soo fun..not fast i know but we weren't timing =P
Ben Lipman
Monday, July 25, 2011 - 06:33 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yang Gao wrote on Monday, July 25, 2011 - 11:10 am:
both.
The whitelines and selby's are adjustable and reasonably cheap. Stomps is onto it- sway bars are absolutely the best bang for buck handling upgrade you will ever buy. A stiff sway bar can have the same effect as stiffer springs, in a corner greatly improving weight transfer and reducing body roll, but you maintain a good ride for day to day driving. You also still have dive (under brakes) and squat( under acceleration) which can be useful or a pain depending on what you are doing.
Nathan Richardson
N.T.
Monday, July 25, 2011 - 07:45 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yang Gao wrote on Monday, July 25, 2011 - 03:24 pm:
The short will make a world of difference now that you have been out on the track without it.
Being off the brakes and on the accelerator when you turn in will lead to understeer as all the weight was on the front of the car and then if you are off the brakes and on the accelerator as you turn in, the weight transfer is moving rearwards.
Generally, from the turn in you want to be trailing off the brakes to be on the throttle by the apex or at the apex depending on the corner as a smooth transition so that you have full throttle at the exit. If it understeers on the way out, smoothly back off the throttle to transfer more weight onto the front wheels.
Do a google search and you will find a fair bit of info out there but the best thing is to get out there as much as you can. Mind you I haven't been on the track since I've been in Darwin but I'm hoping to get out for at least one run prior to the wet season.
Yang Gao wrote on Monday, July 25, 2011 - 06:00 pm:
If you have done a W58 conversion with no other mods I would say that you TRC would be off and I would think you would have a TRC warning?
The TRC button is next to the rest of your buttons near the shifter.
Cheers.
Paul Drane
Monday, July 25, 2011 - 08:01 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The TEMS jumper will only work on Soarers fitted with factory TEMS standard shocks. the air bag cars have a TEMS switch
Yang has the TEMS on and probably set the suspension a bit low if he has aftermarket controller.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Monday, July 25, 2011 - 08:08 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Only warning i have is the ECT warning...
Only buttons i have near my shifter is TEMs, factory low/high height switch, a red button which i have read allows you to engage gears when the car is off on an auto, and the ECT PWR switch which i have been led to believe is the Autos overdrive.
Nathan Richardson
N.T.
Monday, July 25, 2011 - 09:12 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yang Gao wrote on Monday, July 25, 2011 - 08:08 pm:
Actually, now I think about it the ECT error will disable the TRC as there is insufficient input for it, I think.
The switches across the top of the shifter surround (below the ashtray) should include TEMS-Sport/Norm, Height-Low/Norm, TRC-On/Off.
I thought TRC was standard on the UZZ31/2? Maybe it's not? Did you do the conversion your self? Do you have TRC, and is there an amber light on the dash saying TRC off?
Victoria (The Nazi State)
Pretty Red Thing and The Black Beast
Monday, July 25, 2011 - 10:15 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Standard on 32 only, was an option on 31 from 1992.
Nathan Richardson
N.T.
Monday, July 25, 2011 - 11:20 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dan McColl wrote on Monday, July 25, 2011 - 10:15 pm:
Thank's Dan. So there might be the answer then? To this question that is;
Dave Rose wrote on Monday, July 25, 2011 - 05:49 pm:
Phil Gibson
'91 UZZ30, '91 manual UZZ31 track bunky, '94 blk/blk UZZ31
Tuesday, July 26, 2011 - 11:12 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is nothing wrong with the handling of an airbagged soarer, in fact they perform better than a stock coil non-tems one. What you need to be aware of is wheel alignment and handling will change a lot between a fully-lowered car and a fully raised one. Also, any Soarer, airbagged or not on the original suspension will likely have dampers that are stuffed or at least well past their best, this is the biggest cause of the sloppy, boatlike handling.
Secondly, Supra rear sway bars *will not fit* on a soarer without the Supra subframe mounts and brackets (front bars are bolt-on though)
Phil Gibson
Tuesday, July 26, 2011 - 11:18 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is my track car when it still had the stock airbag suspension in
THis is my daily 31, same deal
I have footage of a stock-coil UZZ30 at the same venue, there is noticeably more body roll and general sloppiness (in fact, also a stock suspension R33 Skyline which was worse too!)
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 11:54 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No i don't have anything that says or implies TRC. I didn't do the conversion myself, bought it as is. I'm gonna say i probably don't have TRC.
@Paul Yeah i do have an aftermarket height controller, initially had it WAY too low, getting some mad bouncing around corners. Raised it a bit and all good.
And yes I do have a TEMs switch to control soft/hard but if the jumper setting makes it harder than hard...will give it a shot next time
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 12:45 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Phil Looks like fun, can't wait to get my swaybars in and give it another go. Next couple paychecks gonna be front/rear whitelines and some ICE
Allan Langford
Reg: 05-2010
Tuesday, July 26, 2011 - 02:40 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no problems with my UZZ31 in corners, I need to test it still but it must be close to pulling 1g lateral loads...
whiteline bars and 275/35R18 tires all round helps...
Jerzy Stopczynski
Westarn Australia
jzz20
Reg: 12-2006
Tuesday, July 26, 2011 - 03:13 pm, by:  Jerzy Stopczynski (Stomps) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
RAC track is a fair bit different to a wide race track with sweeping corners though.. how is the air suspension on tight and quick direction changes?
such as the middle section of this:
and a 3 cone slalom etc...
does it react quickly enough? actually curious, mate just bought a z31..
a lot of it comes with time at a track though.. getting used to your car..- like the braking technique that was talked about...
i find that with my car i can go in hard on the brakes, turn in just a tiny bit to get the tires to bite, then jump off the brakes and let the weight transfer slide the tail around... then just control how much slide with my right foot..
if it's not changing direction as fast as i want.. (slide entry into the 2 wide hairpins at either end in vid above) a sharp turn of the wheel combined with a little bit of handbrake helps.. not enough to get the tail all the way around, just enough to shift the weight.. its all about developing a technique that suits you and the car..
i've lost count of how many motorkhanas i've done at AHG/RAC.. at least 30 in the last few years.. plus more in my old a70.. i can honestly say that the 3 biggest things that have made a difference in the feel of the car are:
1. swaybars
2. coilovers (16kg front 14kg rear)
3. LSD (welded in my case)
each modification has affected the car in a different way and forced some form of driver adjustment... especially the weldy... BEST MOD EVER!! lol..
if you plan to do a lot of these, one other thing i would recommend is a decent bucket seat.. you dont necessarily need to keep it in the car all the time, just swap seats before events.. it only takes 5 mins to swap seats.. and is well worth it.. having decent lateral support means you can keep your mind on driving and not on holding yourself in place with your knees..
Im rebuilding my R154 at the moment so will be out again in September.. you should definitely come along..
Stomps
Allan Langford
Reg: 05-2010
Tuesday, July 26, 2011 - 04:27 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it's ok its the dampers that are the issue after 130,000km...
I'm going to gut my airbags and then refit them over a set of JZA80 koni yellows and see how it go's.
Probably leave it at that as its still a road car.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 04:32 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Jerzy The 3 Cone slalom actually isn't too bad, just a bit of weight moving around. Quick direction changes make the car roll a bit on airbags/TEMs though.
Definitely be getting some whitelines, anyone know where to source? I've already got a TRD Diff and want to roll on airbags for street driving still.
Bucket seats is an interesting idea though....are electric seats hard to remove/reinstall?
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 04:49 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Allan Wait what, you can change airbags to something else internally? Got a link or anything like that i can read?
Phil Gibson
Tuesday, July 26, 2011 - 05:39 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
With totally stock airbag suspension and a controller (or with a jumper pin in the port) i guarantee your car will handle better than a stock-coil sprung Soarer, and better than other similar-sized cars too
Jerzy is right though, LSDs and sway bars make a big difference
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 05:52 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
With in regards to the dampener in the airbag suspension, possible to replace? Or have to replace the whole thing?
Allan Langford
Reg: 05-2010
Tuesday, July 26, 2011 - 08:43 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i'll tell you once I cut them open!
hopefully I can make up a collar that will weld to the bottom section of the airbag that contains a O ring to seal to the body of the koni, not sure on the top damper mount yet that will have to wait till i pull it to bits and see how it compares to the koni...
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 10:48 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sigh noticed a clutch issue T.T will see if it develops more over the next couple weeks.
Basically clutch is sitting slightly lower than it was before, in neutral and stationary there is a not so faint mech grinding/whirling sound that goes away when you engage the clutch. Driving, the gears feel slightly more loose =\
Allan Langford
Reg: 05-2010
Wednesday, July 27, 2011 - 06:58 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
checked the gearbox oil?
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Wednesday, July 27, 2011 - 11:35 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not yet, probably try and have a look on sunday, planning a "work on your car day" with a couple mates. Need to find a guide on checking gearbox oil.
It seems to have fixed itself though, while driving to work. Clutch came back to normal levels again. Will see.
Btw here is a teaser for the video my friends working on. The guys a pro so it makes my car look gooood hahaha.
http://www.keeganwong.com/wallpapers/soarer1680x1050.jpg
Theres a album on my facebook of teaser photos for the vid (I'm only in 2 so far T.T). Here's the link, should be public viewable but if not let me know.
http://www.facebook.com/media/set/?set=a.10150271887747460.353220.113518317459&type=1
Can't wait for the video.
Nathan Richardson
N.T.
Wednesday, July 27, 2011 - 08:53 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow Yang,
Your Soarer looks very clean and straight!!!
Very nice!
Matt Sartori
Rx7
Reg: 08-2008
Thursday, July 28, 2011 - 10:58 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That red FC is gorgeous....i've never seen it before
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Thursday, July 28, 2011 - 11:15 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah friends FC, a lot of done to it.
Matt Sartori
Rx7
Reg: 08-2008
Friday, July 29, 2011 - 11:29 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wheres he been hiding?
Never seen it out on any rotor cruises, would love to check it out in person, looks immaculate!
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Saturday, July 30, 2011 - 10:56 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL immaculate, nah mate it is the photos. Bodies in above average condition. And reason it never gets out is because he is always working on it.
Damian Ware
UZZ32
Saturday, July 30, 2011 - 09:49 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just to add about the jumper link and sport settings ect with air bags.
In my experience with brand new struts there is a big difference but many cars with worn suspension the differences is non existant.
Sway bars as others have said and IMO are the best handling value for money mod.
Austen Menze
GT-TL
Reg: 07-2009
Tuesday, August 02, 2011 - 08:43 pm, by:  Austen Menze (Mercyfulfate) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah that's Shay's old manual V8.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Wednesday, August 03, 2011 - 10:50 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, yes it is
