  Soarer Central * General Soarer Chat * Soarer boot struts, ebay junk Previous Previous    Next Next
Brett Harrison
Tuesday, August 02, 2011 - 12:07 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So I bought some boot struts of ebay. link below. From the gas strut guys.
http://www.ebay.com.au/itm/Toyota-Lexus-SOARER-SC-400-Boot-Gas-Struts-New-/120749882091?pt=AU_Car_Pa rts_Accessories&hash=item1c1d40faeb#ht_1813wt_906
Anyway have been lucky to get 12-18 months out of them. Car has hardly done anything it that time, as I share the load between cars. Now they are completely stuffed, will bash you fair on the head if your not careful.
What surprises me is my 91 TT still has original and working well gas struts.
Does anyone know where to get good quality struts, I would consider these gas strut guys struts total rubbish.
Brett
Gary Poloskei
A.C.T
Soarer JZZ30
Reg: 01-2008
Tuesday, August 02, 2011 - 12:46 pm, by:  Gary Poloskei (Mikrucio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought some from ebay 20 months ago. not sure of the seller tho..
actually could of been the same one.
Still great! Dont know mate. maybe you got a faulty pair. talk to them and they will probably send you another set.
Tom Richards
Tuesday, August 02, 2011 - 02:13 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i purchased a set off ebay 2 yrs ago. still going great.
you specified whether you had a spoiler or not.
they were at essendon near the airport.
I think this may be them.
http://www.gas-struts.com.au/Welcome.html
Hakan Pasha
Reg: 05-2008
Tuesday, August 02, 2011 - 03:37 pm, by:  Hakan Pasha (Hakanpasha) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tom Richards wrote on Tuesday, August 02, 2011 - 02:13 pm:
I took mine there to get regassed... two years on and still working great.
Tuesday, August 02, 2011 - 06:38 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
DO you have a spoiler and specify ?
Otherwise unlucky , as i bought mine over 3 years ago from them and still working fine !
David Grima
1JZ-GTE TT
Reg: 07-2007
Tuesday, August 02, 2011 - 07:40 pm, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I also bought these gas struts off ebay from the same company mentioned above about 2 and a half years ago, still working great.... think you must have just been unlucky with your set Brett
Brett Harrison
Wednesday, August 03, 2011 - 09:49 am, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, I specified no spoiler, as its for a UZZ30.
I did send them an email, not to interested.
Just sent me a one line reply
"They have a 12 month warranty Brett"
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Thursday, August 04, 2011 - 09:42 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have been thinking of getting these as I'm a bit over using a broom stick!
I thought they we pretty reasonable? And as far as boot struts go, it wouldn't be something I would loose sleep over!
Monday, August 08, 2011 - 07:20 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The OEM struts are very high quality, just get them re-gassed. Got mine done a year ago, still going strong.
Friday, August 12, 2011 - 03:25 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine were regassed many years ago and still going strong too.
John Jantzen
Tasmania
V8 '31
Friday, January 20, 2012 - 09:33 am, by:  John Jantzen (Taslex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought some Gabriel "Strong Arm" 4508 struts from Supercheap way back in early 2006 (there is a thread about this) and they worked well for the four years I had the car. They did weaken slightly, but were still able to hold the boot lid up OK. Maybe Supercheap still sells or can get these?
Ben Lipman
Friday, January 20, 2012 - 09:19 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought the one from supercheap and they are worse that the factory ones I replaced in less than 4 years.
I need to find my stock ones from the track car and get them regassed somewhere. It is very embarassing having to hold your boot open with your head on a 'prestige' car.
Saturday, January 21, 2012 - 12:00 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, not your side of town, but he also does a mobile service.
http://soarercentral.com/sc-forum/messages/281/244860.html
Ben Lipman
Saturday, January 21, 2012 - 01:20 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cheers- will se if yellow pages/google turn something up my way. Or I'll call him and see if he is out here at all.
