Friday, August 19, 2011 - 12:05 pm, by: Tom Richards(Tomr)
a mate with a TT has put a small amount of power steering fluid into the brake master cylinder.
He is now having problems with the pedal going to the floor. His mechanic has told him the power steering fluid will settle on the bottom ,and destroy the seals.
Friday, August 19, 2011 - 01:27 pm, by: Aaron Casey(Blownminiturbo)
yes the power steering will swell the brake seals.. damage is probably already done. will probably need calipers rebuilt and also master cylinder.. ive had a few people do that before to cars. the oil swells the seals and seizes the caliper pistons and master cylinder.. expensive mistake whoever put the oil in the brake fluid
Friday, August 19, 2011 - 01:32 pm, by: Dave Rose(Sand_groper)
YES !!! CANNOT BELIVE HE DID THIS??, sorry to tell you this but all seals inc master and flexable pipes have gone ,he will need to flush the system also.
Friday, August 19, 2011 - 01:42 pm, by: Tom Richards(Tomr)
thks aaron, he is now in the process of bleeding all the brakes. Do the seals return to normal after "being flushed" with brake fluid, or are they stuffed.
I guess his options are rebuild all slaves and the master, or find a good 2nd hand set and replace the lot.
Friday, August 19, 2011 - 07:02 pm, by: Dan McColl(Hoon)
Nope, Seals are all Factus, as are the rubber flex hoses out to the wheels.
Master and wheel cylinders need to be stripped, flushed and rebuilt with new seals, and the flex lines need to be replaced, or it's likely he will have a brake line failure down the track, possibly whilst needing to stop quickly from high speed.
Friday, August 19, 2011 - 07:09 pm, by: Shane Haverkamp(Havabeer)
so whats in power steering fluid that goes so nasty with brake fluid. never heard of this happening not that i'd ever put power steering fluid anywhere other then power steering and auto trans.
