Sunday, September 11, 2011 - 03:30 pm, by: Oleg Akulshin(Sliqu3)
Hey guys I am currently in process of wiring up emu on my 1uz and as many might know the emu software doesn't have base settings for 1uz, so I wondering what the ignition type 1uz run? 12v or 5v also what type of karmanvortex is it 1 or 2? Also is there any offset angle? Cheers
Monday, September 12, 2011 - 06:46 am, by: Oleg Akulshin(Sliqu3)
Got it all hooked up and the car finally starts... BUT the IGN i had to disconnect since i there is no setting for 2 ign outputs and 2 inputs for a v8. Should that be set to 4 cylinder with group IGN output with capacity of 2000 or 4000? Injectors are running fine, also i dont get the RPM signal, EMU just shows 0. Rpm signal i hooked up to to tach signal from ECU, should i change that to IGF or CAM/Crank angle sensor, if so what are the cam sensor paramenter? Also since are injectors are in group of two, should i set double the flow rate in the parameter setting? eg 251X2 cc/min, If anyone also knows correct KNOCK sensor settings that would be appreciated, eg (resonant/nonresonat and the frequency)
Friday, September 16, 2011 - 06:12 pm, by: Oleg Akulshin(Sliqu3)
IT WORKS IT WORKS IT WORKS!!!! After spending a week on jap forums and looking through wiring diagrams it turned out to be just a badly crimped wire.... DOH!
