  Soarer Central * General Soarer Chat * Anyone has a good condition working ECU that i could borrow? Previous Previous    Next Next
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Tuesday, September 27, 2011 - 08:10 am, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone out there kind enough in Melbourne to help out, just need to test if there any problem with my ECU by plugging in another(your) ECU.
Joshua Baldwin
1990 ucf11 c+f celsior. 1991 uzz31 toyota soarer 2003 vy sv8 ute
Reg: 10-2009
Tuesday, September 27, 2011 - 05:19 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have one you can use but im not in melb
Kurt Atzmuller
TT`s
Reg: 05-2011
Tuesday, September 27, 2011 - 05:25 pm, by:  Kurt Atzmuller (Kurt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey i have one i'm in melbourne area! When do you need it??
Kurt Atzmuller
TT`s
Reg: 05-2011
Tuesday, September 27, 2011 - 08:44 pm, by:  Kurt Atzmuller (Kurt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry mate i've only got one for a tt. Unless your after a twin turbo one!
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Tuesday, September 27, 2011 - 08:50 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kurt: Ah, i'm after a V8 one, thanks anyway buddy.
Joshua: ah man, not convenient for me to travel far this time, appreciate your offer!
Joshua Baldwin
Reg: 10-2009
Tuesday, September 27, 2011 - 09:00 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
whats your prob man with the car whats it doing etc?
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Tuesday, September 27, 2011 - 10:24 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actually its still the transmission issue, i changed the transmission, changed solenoids 3 and 4 on it, and its still the same issues (change of gear from park to drive, "jerks", as i drive, gear changes from 1 - 2 and 2 - 3, jerks as well).
Basically i jumped the gun hoping to fix the problem but apparently it isn't mechanically at fault, thus only leave electrical issue.
