Some issues have surfaced, i realize as i drive, sometimes between the speeds of 20 - 30, when i hold the accelerator in the position, the RPM will fluctuate, sometimes between speeds of 70 - 80 on the highway, anyone knows anything about this or have faced this before?
Saturday, October 01, 2011 - 11:33 pm, by: James Buchan(Jrbuch)
No idea if it would relate to the tune you've got on the E-manage blue? Maybe worth seeing a tuner to see if you can improve things there? Throttle cable all nice and tight?
James: Throttle cable just got looked at, tension's not too tight and not loose. But yeah, perhaps worth a look with regards to the E-manage blue.
Ali: Just drops and comes back up again, fluctuates down and back to normal when i depress the accelerator further in. Transmission just got looked at, certain small components that needed to be changed was changed in the transmission. This happened when it was on my previous transmission as well, so i'm guessing it shouldn't be the transmission.
Sunday, October 02, 2011 - 03:41 pm, by: Brett Harrison(Bretto)
Mate take it for a drive with the AFM disconnected, hows the idle ? RPM when hot ? any surging ? You can also take it for a drive with the ISCV disconnected, it will want to stall just keep revs up with throttle.
