  Soarer Central * General Soarer Chat * 1JZ VVT-i vs 2 JZ VVT-i, which would be a better choice? Previous Previous    Next Next
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Sunday, October 16, 2011 - 11:07 am, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just starting a thread to see which would be a better buy, on stock condition, it appears that the 1JZ VVT-i (Single Turbo) pack more power as compared to the 2JZ VVT-i (SC300 NA).
What i am asking here, which engine would be easier to do light mods (nothing fancy such as huge turbos, just ECU and stuffs) and probably if anyone has any other inputs to this topic could suggest something.
Jason Cheah
MINE'S 2JZ-GTE JZZ31
Sunday, October 16, 2011 - 02:39 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apples and oranges. But if you even want to start modifying REGARDLESS of how LIGHT... the 1JZ is the go.
If you want better fuel economy or P Plater; 2JZ VVTi.
James Buchan
Reg: 10-2008
Sunday, October 16, 2011 - 09:25 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I went on a cruise when I first got my Soarer, and it was around 2009. We went down the Great Ocean road. A white 2J vvti came along, and at no stage was he lacking power. It had coilovers, and a nice sounding exhaust, out of corners it was plenty quick and had no troubles keeping up with the V8's and 1J's.
A friend has an Aussie delivered GS300 with the 2J vvti, and it hauls @rse for a 3.0 NA engine.
That said, if you're wanting to wind the wick up, or seriously smoke the tyres, search for a vvti 1J.
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Sunday, October 16, 2011 - 11:33 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cool inputs, probably might go for a white 1JZ VVT-i single.
Scott Casey
soarer v8
Reg: 02-2008
Monday, October 17, 2011 - 06:47 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the winner of the 2 engine's would be the availability of aftermarket parts.
power is not everything
torque everything
Ian Johnston
UZZ30 GT 4.0, BA XR6Turbo Ute. 2007 VE GTS.
Monday, October 17, 2011 - 07:49 am, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In saying that Scott, I would have thought there would be plenty of options for both engines??
Or is one more popular than the other( I am a V8 man), but would love to have either of these options in my shed.
Scott Casey
soarer v8
Reg: 02-2008
Tuesday, October 18, 2011 - 06:55 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://wiki.jzx100.com/index.php?title=VVTi
EBAY turbo manifold search "SUPRA 1JZ GTE VVT-i turbo manifold"
Power House Amuse http://www.webamuse.co.jp/new/jzx100/
Do-Luck: http://www.do-luck.com/jzx100_ex.html
Traum: http://traum.cc/shop/html/products/d...product_id=218
Kazama: http://www.kazamaauto.co.jp/base4.html
Garage Miniz: http://www.garageminiz.com/parts001exmanirb2025.html
Garage Miniz http://www.garageminiz.com/parts001exmanisr20.html
HPI: http://web.mac.com/emihpi/iWeb/HPI-E...0Manifold.html There is also a Version 3 not advertised
Rasty: http://www.rasty.tv/rasty/ex_mani.html <---- number 1 manifold for jzx100 owners
HKS: http://www.hks-power.co.jp/db/produc....aspx?N_ID=176
Garage Total: http://www.garagetotal.com/html/auto02-exparts-016.html
katsuadia works http://www.katsutadaiworks.com/new-products-1
exhaust:
katsutadia works http://www.katsutadaiworks.com/drift-pipes
katsutadia works Jzz30 s2 full exhuast http://www.katsutadaiworks.com/jzz30-soarer
eletrical and Tuning:
Greddy v-magagment system
http://www.jdm-option.com/eng/parts/...manage_top.jpg
http://www.jdm-option.com/eng/parts/07_01/vmanage.html
http://www.trust-power.com/03electric/vmanage_kit.html
hks valcon vvti tuning system http://www.hks-power.co.jp/products/...on/valcon.html
AMUSE r100 rom i have the pics if intrested
Mine's (theirs a rumor about a piggy back for the vvti jzx100)
power enterprises CamCon vvti controller http://www.powerenterpriseusa.net/pr...con/camcon.htm
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Wednesday, October 19, 2011 - 10:51 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1JZ VVTi for overall performance, the 2J is a good base to work on (visit NA-T.com) as the engine is very similar to the GTE with exception to oil squirters, intake manifold, compression (N/A compression + turbo = awesome!)
Personally I'd pick the 1J as it's ready to go and the standard single (CT15b) turbo can withstand a good 250rwkw.
Orton Marchant
NSW Blacktown
Reg: 01-2011
Thursday, October 20, 2011 - 09:04 am, by:  Orton Marchant (Mythorite) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
but the 2jz n gte is pretty much ready to go just drop it in all you pretty much need is the loom and a management, for my car already have that stuff so it is just drop in,
but ive heard you can get a 2jz engine and put the 1gz block in or vise versa? something similar to that anyway
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Thursday, October 20, 2011 - 02:54 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the inputs people, yeah i guess i'm going ahead with the 1J as what christian mentioned, its a ready to go set up and i'm not that hardcore of a fan of that much power up till 400 bhp (although having a 1001 hp veyron would be nice.
Just need something with a fair amount of power, decent on fuel, good for cruising in and has the power when i need it (sometimes when i want to feel the "adrenaline rush").
