Tuesday, August 14, 2012 - 03:39 pm, by: Daniel Clarke(Dieseltrain)
Yep , have a look at the plastic inner guard liners . They can tear down on the tyre and there is an electrical harness on the v8 from memory that can be affected if not checked out .
Jack the front up , remove both wheels and check for marks or wear on the plastics . Could be from being broken or broken screws not holding them up properly .
Thursday, August 16, 2012 - 07:42 pm, by: Peter Nitschke(Pen)
Chris, if the PS fluid is old and burnt, that can cause the pump to sound bad. I flushed one of mine when it was noisy with the level being OK, and the flush worked a treat.
