  Soarer Central * General Soarer Chat * Help after soarer was stolen Previous Previous    Next Next
Brian Cornwall
qld
v8
Reg: 11-2011
Tuesday, February 05, 2013 - 11:29 pm, by:  Brian Cornwall (Fugz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi need help some lowlife went into my gf house while she was asleep and stole her handbag and keys to the soarer and stole the car
now the police just fount it but now we have no keys and it has an imobiliser what do i need to replace and where to find it or is this just a parts car now
Tuesday, February 05, 2013 - 11:38 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Contact a mobile alarm guy . Remove old alarm and install new one . Also get them to make new keys .
Going to cost a bit , but with different keys and alarm the other lowlife scuff won't be able to use the existing keys to get it again .
Joshua Rao
TT (for sale $5.2k), 97 Blk UZZ31, 97 JZZ30 vvti turbo white manual, 96 vvti turbo manual, Legnum VR4, MR2 sw20, Alfa 156
Reg: 09-2006
Wednesday, February 06, 2013 - 11:33 am, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry to hear that!
I can send a second hand ignition barrel and key to you for about $80posted
Tom Richards
Wednesday, February 06, 2013 - 01:00 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there are posts on here and also youtube and google with a how to rekey barrels to fit your key. I think lock smiths can also cut a key from a barrel.
contact the supplier of the immobilizer and get a new control with instructions on how to reprogram it
both you problems are "minor."
Steve Gorman
Wednesday, February 06, 2013 - 11:35 pm, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brian
I bought a repossessed car at auction with no keys or alarm remote.
There is a code marked on the inside of the drivers door lock. Specialist locksmiths can cut keys to that code. I have done it with a jzz31 and Independant Locksmiths in Parramatta.
For the Imobiliser I contacted the local agent for the brand of immobiliser and purchased a new circuit board (which came with 2 remotes) and simply replaced the circuit board without having to touch the wiring.
hope this helps
Steve
