  Soarer Central * General Soarer Chat * UZZ32 general suspension question Previous Previous    Next Next
Kevin Peter
V8 UZZ31 GT Limited
Reg: 07-2011
Tuesday, June 25, 2013 - 03:51 am, by:  Kevin Peter (Inspire) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Out of curiosity, just wanted to ask about the UZZ32 suspension. When the suspension is set on normal instead of sport, is it more comfortable than a 31 (airbag) or about the same? Im well aware of its handling characteristics on sport mode compared to all the soarers. However wondering how is for cruising around? Any better than a 31? if so could you describe how it feels?
Tom Richards
Tuesday, June 25, 2013 - 09:18 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/5079/369773.html?1364194102
send john stafford a pm. he has a 32 and a 31
Martin Quinn
Soarer UZZ32
Reg: 02-2010
Tuesday, July 02, 2013 - 01:52 am, by:  Martin Quinn (Martinq) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Normal/Sport switch does not affect ride comfort - well at least not noticeably in mine anyway; it just changes gearbox behavior. It is an odd ride, the best that I can describe it is that you feel everything but it is more like it is telling you what the road surface is like rather than uncontrolled harshness. It doesn't give the impression of softness, it actually feels quite stiff - but the actual force felt in the car is quite gentle. An exaggerated example would be driving a gravel rally on a Playstation, the force feedback makes it clear that the road is rough but you don't actually get shaken to pieces. Of course if a pot hole is big enough it still hurts; it can only do so much...
