Scott Vim
Goo Roo Vic Soarer (1uz) Chaser (1jz)
Posts: 1385 Reg: 12-2010
| Here's the results. Didn't gain as much as I was hoping. Made about 25rwkw more and 50nm of torque. Its hard to see but the yellow line is e85.
James Buchan
Goo Roo Vic vvt-i turbo 6 speed manual
Posts: 1885 Reg: 10-2008
| But how does it drive? And are you happy with it compared with the Tomei M8280? |
Blake Gloyn
Goo Roo manawatu soarer JZZ30 TT
Posts: 1248 Reg: 02-2006
| 50 more kW at 3000 rpm!!! |
Blake Gloyn
Posts: 1251 Reg: 02-2006
| and what boost did you run? |
Scott Vim
Posts: 1386 Reg: 12-2010
| Yeah down low torque is just crazy. Boost was left untouched because I want to be able to run 98 without changing the boost settings. Its about 18-19 psi. |
Matthew Salkeld
TryHard South Australia 1JZ powered 180sx
Posts: 257 Reg: 07-2008
| Great results, I'd be happy with that |
James Buchan
Posts: 1886 Reg: 10-2008
| Well that's all that matters then! Down low torque must make it very fun! And it must be rather quick as a result? |
Scott Vim
Posts: 1388 Reg: 12-2010
| Yeah it's good to drive. It made the same peak power as the Tomei (on 98) but is totally different to drive. It would bog down unless you had the revs high and brought the clutch up just right. A normal take off with the tomei would make the car seem so slow. Then out of no where 4,500rpm it would completely go nuts. I think its pulling just as hard now but it doesn't come on suddenly. It feels quicker and isn't a slug under 4,000rpm. |
James Buchan
Posts: 1887 Reg: 10-2008
| Let's see how I go with mine eh? I'm hopeful a good standalone, a dash of E85 and my j-pipe delete and manifold can make an improvement to the Tomei. My new 1NZ coils should help with spark and I should have some nice steady AFR's as a result. I got sick of the auto, which didn't help with the lag, but once I hit 3000rpm as you said, it would go nuts and you'd be well and truly over the speed limit. Head to the drags mate, see what time you pull You might be pleasantly surprised! |
Kurt Atzmuller
DieHard Victoria TT`s
Posts: 762 Reg: 05-2011
| Nice work Scott! Could you give me a run down of your mods please mate or do you have a build thread somewhere on here? |
Tai Johnsen
Goo Roo QLD JZZ30 Pov Manual LSD & black!
Posts: 1576 Reg: 04-2006
| Did it get any more timing in it with the tune? |
Scott Vim
Posts: 1389 Reg: 12-2010
| Yeah mate it's a 1jz vvti. Has a bolt on blitz turbo. 850cc injectors, 430l/h e85 walbro fuel pump. FMIC, 3" turbo back exhaust. Emanage ultimate. Few minor things can't think of everything but did 3 new coil packs and 3 new leads (4 years ago). Plugs gapped to 0.8 and one heat range colder. I was thinking of putting one of those off road use only cats in it to get me a few more gains. It feels great now but I feel at the 280rwkw mark it will be a weapon with this response. |
Scott Vim
Posts: 1390 Reg: 12-2010
| Yeah Tai the tuner told me it made 273rwkw but it had a bit of pinging so he took the timing back a little and then some for safety margin and final figure was 266kw. I want to make a 12.9 second or better 1/4 pass. It feels like it might be there especially with some grippy tyres. |
Ricky Liddy
Tinkerer Vic Pearl White TT
Posts: 58 Reg: 06-2011
| All that extra power down low would be great. If you don't mind me asking, who did the tune for you? |
Scott Vim
Posts: 1392 Reg: 12-2010
| Craig Pisa @ Revzone. He doesn't like Emanage but will still tune it. |
Blake Gloyn
Posts: 1253 Reg: 02-2006
| i'm surprised he could make it ping on e85. |
Goo Roo New Zealand UZZ32 No.32 & JZZ31 3.0GT
Posts: 5832 Reg: 11-2005
| Most impressive. Love the gain at 3000rpm like Blake mentioned. |
Kurt Atzmuller
Posts: 763 Reg: 05-2011
| Great gains.. I now have a servo selling e85 5 minutes from my work so its an option for me now. I will definitely give it a go when my car is back on the road. |
Robert Faggian
TryHard Victoria UZZ31 and VVT-i JZZ30
Posts: 358 Reg: 02-2009
| To James, or anyone else that can comment - you've mentioned a few times that going to a Tomei increased your lag substantially. If you had your time again, what would you do in terms of upgrade path? I was thinking of a Tomei for my VVT-i but not if it only kicks in well past 4000 rpm. |
James Buchan
Posts: 1888 Reg: 10-2008
| Robert, i've often thought about that. If doing my time again, I'd choose something like an internally gated GTX3076 (with an adaptor plate to the factory turbo manifold) The key is making sure it has a ball bearing center, as this should help it spool up a little quicker. The Tomei M8280 Arms turbo has a journal bearing. Another option would be a HKS 8260. I don't hate the Tomei, it's been a good bit of kit to me thus far. I wanted something that would come with all the stuff needed to bolt it on, and I knew little about other available turbochargers at the time. Tomei's claim that it has near factory response is a blatant lie. I've found that the Tomei M8280 greatly relies upon supporting mods; the more you have, the more you'll get out of it. For instance, I ditched a dual 2.5inch exhaust and went to a single 3.75inch exhaust, and the gains were monumental. Once my car is finished, I think I'll have pushed the Tomei turbo to it's absolute max, and it will be interesting to see how it responds to E85. I can update you then if you'd like. If not going too wild, you could always fit a steel wheel to your factory turbocharger, and upgrade the internal wastegate with a stronger spring. This would be a good compromise between response, power and not going overboard.
You can get some ideas from this thread regarding mounting a GT3076 on an adaptor plate using the stock 1j vvti Soarer manifold. http://soarercentral.com/sc-forum/messages/51875/294314.html?1265498823 In conclusion, the Tomei isn't bad, but an adaptor plate with a GTX3076 would be the go. Might involve a little more hands on work getting oil/water lines made up, and a dump pipe, but in my opinion a more versatile turbocharger. |
Scott Vim
Posts: 1393 Reg: 12-2010
| I took the Tomei off. I think if you do all the supporting mods and push 300rwkw is will be pretty decent. By itself I think it's too big f or the 1jz. It wasn't just laggy it was completely gutless under 3,000rpm. In a manual it just wasn't fun. Either I had to be giving it heaps or driving it like a grandpa. There was no in between. In an auto I think it might be better. I would just high flow the stock for good gains and driveability. I found this blitz turbo at a decent price so went with that. |
Robert Faggian
Posts: 359 Reg: 02-2009
| Thanks James, Scott. Good information as always. |
