  Soarer Central * Events, Cruises, Dyno and Track Days. * WA Events * Dyno Day 15th October * Archive through October 18, 2005 Previous Previous    Next Next
JunkFilterer
Monday, October 17, 2005 - 04:42 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So as well as CBO/CEO you are also the Bling Babe? Or is that Neon Queen?
Shane Ilich
W.A.
Monday, October 17, 2005 - 05:05 pm, by:  Shane Ilich (Ferret) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i like "Tokyo Sam" - her car's full of rice, and covered in neons
Samantha Hornby
Manual TT
Monday, October 17, 2005 - 05:14 pm, by:  Samantha Hornby (Soarer_chick_1jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
...at least it has pedals and a gear box.
Shane Ilich
W.A.
Monday, October 17, 2005 - 05:25 pm, by:  Shane Ilich (Ferret) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Samantha Hornby wrote on Monday, October 17, 2005 - 05:14 pm:
its called "weight reduction" - whats the two heaviest things in your car???
the engine and gearbox, of course........
Adam Lonergan
RSA Colt TD
Monday, October 17, 2005 - 05:40 pm, by:  Adam Lonergan (Alchemistal) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Engine... gearbox... driver
Monday, October 17, 2005 - 09:01 pm, by:  Callum Finch (Sigeneat) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm a girl.
EDIT: whoops! wrong thread
Phil Gibson
'94 black/black UZZ31
Monday, October 17, 2005 - 09:07 pm, by:  Phil Gibson (Sciflyer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe the next club event should be the Callum Coming Out party
Todd Williams
JZA70 R / BLMQZ
Tuesday, October 18, 2005 - 12:24 am, by:  Todd Williams (Jza70_r) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for letting the supra run Paul!
FYI Xspeeds dyno and HyperDrives dyno is within 1 hp of each other! very good to see.
Is Mark.H (1BGD456) on this forum? wanna talk to him about his mods...
and here are a few photos
Samantha Hornby
Manual TT
Tuesday, October 18, 2005 - 10:04 am, by:  Samantha Hornby (Soarer_chick_1jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Woo! Spotted my baby way up in the back
Peter Scott
Active V8
Tuesday, October 18, 2005 - 10:18 am, by:  Peter Scott (Planetsoarercom) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great stuff guys. Is there a list of mods for each Soarer somewhere?
Tuesday, October 18, 2005 - 10:24 am, by:  Callum Finch (Sigeneat) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was number 16, click my name?
Samantha Hornby
Manual TT
Tuesday, October 18, 2005 - 10:49 am, by:  Samantha Hornby (Soarer_chick_1jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL
Blaine Hanson
Tuesday, October 18, 2005 - 10:53 am, by:  Blaine Hanson (Blaine) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Todd
Mark H is not on this forum - yet - but I built the car - I'm his dad ! Then I sold it to him as I still prefer the V8's. It is not far from stock. The only mods are ... It has a dump pipe, pretty much standard exhaust, Trust front mount intercooler - 4" thick - everyone now says I should have gone 3" as you get more air through them, and an electronic E-Boost set at 12 psi. X-Speed did the intercooler and E-Boost install. Anything over 12 psi and she hits the fuel cut out. The rest are only cosmetic changes. If it was my car ( again ) I would install the big twin pipe turbo exhaust exit pipe upgrade to the dump pipe to get away from the stock turbo exhaust manifold and also open up the exhaust a little more - size wise - and with less bends. I think that would get you close to the max HP of a standard ceramic wheeled stock system.
Also we must remember it is a factory manual ( R154 ) so you loose less HP through the box as well. After this you get into the bigger $'s and I was going to copy the basic setup of Emanuel Spinola car - 327 KW ( 438HP )
Peter Scott
Active V8
Tuesday, October 18, 2005 - 02:11 pm, by:  Peter Scott (Planetsoarercom) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have updated the dyno library and converted the hp to kW as well. Any edits please email me and I'll gladly make the change.
http://planetsoarer.com/dynolibrary/dynolibrary.htm
Todd Williams
JZA70 R / BLMQZ
Tuesday, October 18, 2005 - 02:18 pm, by:  Todd Williams (Jza70_r) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for that Blaine, i was more curious to Marks output because it was so close to mine, actually a couple hp more.
i have custom twin dumps off the turbos going into a complete 3" system including 3" cat, and a apexi pod filter, thats about it and yeah shes a manual. with those mods boost naturally hits inbetween .8 and .9 bar (12/13psi). im still using the stock fmic.
thanks again.
-Todd.
Andreas Niaouris
W.A.
Tuesday, October 18, 2005 - 02:28 pm, by:  Andreas Niaouris (Andreasn) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers guys,
I was crook and only back at work today, I'll spend the next couple of days putting that writeup together. Thanks Paul again for organising the day and to those that posted pictures 'n' results. Was great meeting you all.
Paul Brockbank
Tuesday, October 18, 2005 - 03:47 pm, by:  Paul Brockbank (Brockas) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Brockbank
Paul Brockbank
Tuesday, October 18, 2005 - 03:49 pm, by:  Paul Brockbank (Brockas) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Samantha Hornby
Manual TT
Tuesday, October 18, 2005 - 04:05 pm, by:  Samantha Hornby (Soarer_chick_1jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great pics, Brockas! *still pouting over that SS Ute!*
