  Soarer Central * Wanted to Buy * Uzz32 driver side lower control arm Previous Previous    Next Next
Oki Zoubari
south australia
uzz32
Reg: 03-2010
Friday, May 11, 2018 - 12:49 am, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone know where I can get a 32 driver side lower control arm
Clarke Traeger
UZZ30 V8
Reg: 06-2009
Friday, May 11, 2018 - 05:14 pm, by:  Clarke Traeger (Clarke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Assuming that you want lower front- just got both left and right from EBay. Supplied by North American Suspension (NAS) Great service and at $830 inc freight a bargain compared to local.
Jan van Berendonk
2 x UZZ31 - White and Silver
Reg: 08-2012
Friday, May 11, 2018 - 07:07 pm, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
UZZ30 is not compatible with either UZZ31 or UZZ32
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, May 11, 2018 - 08:37 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oki, I'm assuming it's a 32 RH front you want, are the bushes shot or the ball joint?
Oki Zoubari
south australia
uzz32
Reg: 03-2010
Friday, May 11, 2018 - 08:48 pm, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bushes were replaced a few years ago original, it is the ball joint that is the problem
Correct front
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, May 11, 2018 - 09:18 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Used is likely to be suspect also, was a guy in Tassie wrecking a 32, Jacob Spencer (facebook). Not sure if he still has LCAs or how good they are. Phil Ryrie is looking into renewing the ball joints also. Hope you get it sorted.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Saturday, May 12, 2018 - 04:58 am, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is a guy in Sydney that will do full reconditions for you, with, he has done mine and as good as new, all new parts etc.
Oki Zoubari
south australia
uzz32
Reg: 03-2010
Saturday, May 12, 2018 - 10:18 am, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Link
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Saturday, May 12, 2018 - 12:45 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there are a few companys, i am still looking for the guy i used I think it was THE BALL JOINT DOCTOR , all one word is his email i think. he has no web site, but there are some others like PROCHECK AUTOMOTIVE, ACCURATE STEERING P/L, I am sure those companys sub out to him anyhow.
