  Soarer Central * Wanted to Buy * UZZ32 Washer bottle + pump Previous Previous    Next Next
Michael McKellar
Mini
Reg: 08-2008
Monday, October 22, 2018 - 10:45 am, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know its a long shot, but does anyone have a UZZ32 washer bottle (the one behind the passenger side strut) and pump?
Mine has a gaping hole and the pump has one of the outlet barbs broken off.
cheers
michael
Monday, October 22, 2018 - 03:46 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it different to the bottle in other Soarers?
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Tuesday, October 23, 2018 - 10:48 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes. The 32s have 2 washer bottles. 1 for soapy water, the other for clean rinse water.
Steve Gorman
Wednesday, October 24, 2018 - 08:12 am, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi
this might lead somewhere..
On gumtree a seller is advertising a uzz32 ecu that was taken from a car being wrecked. maybe he can point you in the right direction.
His name is Daniel on 0417295636.
cheers
Steve
Wednesday, October 24, 2018 - 12:41 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had one lying around, ditched it about a year ago.
I think you will find that all early V8's had them, my old 91 UZZ30 did and I am pretty sure my spare one came from an early UZZ31.
Michael Brogefjord
Wednesday, October 24, 2018 - 12:49 pm, by:  Michael Brogefjord (Michaelb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
FYI the front bottle would be the same between Uzz31 and the UZZ32, but not the side one.
Wednesday, October 24, 2018 - 01:11 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Curious, why would they need a different side bottle?
Michael McKellar
Mini
Reg: 08-2008
Wednesday, October 24, 2018 - 11:22 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Wednesday, October 24, 2018 - 01:11 pm:
Because UZZ32.
Michael McKellar
Mini
Reg: 08-2008
Wednesday, October 24, 2018 - 11:36 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is the disaster i have now. Someone did not realise that silicone won't adhere to plastic
Michael McKellar
Mini
Reg: 08-2008
Wednesday, October 24, 2018 - 11:38 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
part number is 060351-603
Steve Gorman
Thursday, October 25, 2018 - 07:56 am, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Michael
I just tried toyodiy.com to see if this part number was used in another Toyota but it indicated the number was invalid. perhaps a digit missing?
There is a soarer specialist in the uk
"Smithies soarer sanctuary" which claims to specialise in 32's. they may be worth contacting.
www.smiffiessoarersanctuary.co.uk
cheers
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Thursday, October 25, 2018 - 01:49 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow that's a messed up silicon job, I have a spare one somewhere, I will see if i can find it.
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Thursday, October 25, 2018 - 03:03 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
85315-24050 is the part number. 32 specific & not available new, as far as I can see. Common for the top corner closest to the motor to disintegrate, unsure if this is due to the exhaust manifold heat or service mistreatment.
Michael McKellar
Mini
Reg: 08-2008
Thursday, October 25, 2018 - 09:12 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was going off the part number moulded into it by Denso. Checked the Denso site as well, not recognised amongst the hundreds of Toyota parts they prefixed with 060351.
Might have to get my carbon fibre moulding skills back up to scratch. Difficult multi part mould with undercuts to account for, but if they could injection mould it, we can rebuild it!
Michael McKellar
Mini
Reg: 08-2008
Thursday, October 25, 2018 - 09:15 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Roland Elliott wrote on Thursday, October 25, 2018 - 01:49 pm:
That would be grand. Might finally get over to your place to check out your car!
3UZ-FE V8 4.3 UZZ32
Monday, October 29, 2018 - 06:41 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I deleted mine and rewired the pump system to use the front washer bottle for both front wiper fluid buttons and also the rear.
They are too brittle and cooked these days, even the good spare I used as a spare has started to fatigue, it's a very hot location.
Of course they are all discontinued parts anyway.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Tuesday, December 25, 2018 - 04:36 am, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I do have a spare one , I also have a better one in my car, I think some last longer than others for some reason, both of mine do not leak and are in great condition.
Jan van Berendonk
2 x UZZ31 - White and Silver
Reg: 08-2012
Tuesday, December 25, 2018 - 10:25 am, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Could you adapt the unit from the series 2 Soarers that is under the guard on the passenger side and fills from near the battery? It pumps water to both screens.
Jan van Berendonk
Reg: 08-2012
Tuesday, December 25, 2018 - 10:29 am, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Could you not adapt the series 2 water bottle that sits under the passenger guard a fills near the battery? It also pumps to both screens.
Michael McKellar
Mini
Reg: 08-2008
Saturday, May 30, 2020 - 03:45 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jan van Berendonk wrote on Tuesday, December 25, 2018 - 10:29 am:
UZZ32 has the valve body for the suspension there. Don't think there is the room to retrofit a bottle there.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Sunday, May 31, 2020 - 06:08 pm, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Correct , no room left to put one there.
Michael McKellar
Mini
Reg: 08-2008
Friday, June 05, 2020 - 08:36 pm, by:  Michael McKellar (Mickmini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Roland Elliott wrote on Tuesday, December 25, 2018 - 04:36 am:
Hey Roland, if you are interested in selling, I have sent you a PM.
cheers
michael
