Tuesday, October 23, 2007 - 07:43 pm, by: Ben Kelly(Ace)
Hey Sarjon, you wont have any luck re the recon. If you are after 2nd hand shipped you can contact 0737156474 (qld). I havent contacted them myself yet so if you do let me know how goes.
Wednesday, October 24, 2007 - 08:15 am, by: Sarjon Toma(Sarj0208)
Actually I got lucky some guy bought brand new struts and totalled his car within two weeks (unlucky for him). I bought a pretty much brand new strut for $300
Wednesday, October 24, 2007 - 09:17 pm, by: Chris Papas(Papasc)
Went through the same process over the last 6 months. Went through 2 second hand front right. No warranty etc, old as the originals and probably just as troublesome. Bought a brand new one, $865 delivered.
Want to keep the car as original as possible, I would rethink seconds.
Adam Peterson Goo Roo Western Australia Lexus Roller Coaster
Friday, October 26, 2007 - 05:25 pm, by: Evan Kaio(Knave)
Sarjon. Is "Lefty" leaking oil or air? If it's leaking oil, buy a new one. Your better off buying a new pair,if funds allow. If 'ol lefty's' leaking air, you might be able to save it.(untill funds allow to buy new ones). Somewhere on this on this forum, someone described how they fixed an air leak out of the top of the strut using Araldite. I tried it.It took quite a few attempts at stopping the air leak.
Sunday, December 30, 2007 - 04:31 pm, by: Fred Azzarello(Sc400iinetnetau)
The front left shock goes first probably because it gets the most average usage. Every time you go through a round-about the front left is taking the greatest load. Same reason front left tires wear faster. Just a guess!
Thursday, January 03, 2008 - 09:11 pm, by: Wess McManus(Bar)
My front left airbag shock is not brilliant either. I have seen instructions for adjusting to "trackday" diagnostic mode.. Would this be a good short term solution? If left on this setting for an extended period could it decrease the lifespan of the shocks? cheers
Friday, January 04, 2008 - 11:17 am, by: David Gough(Tasoarer)
My front left also let go after trying the track day diagnostic mode. It appears that it's pushed the strut insert up and cracked the top seal in the air bag.
So I'd probably suggest against using that paperclip trick. If you want it too handle go buy a set of springs ;)
I did a temporary repair on mine with sikaflex and a turned up ring pressed back into the top, but it goes down over night. I've got another one lined up, but at the end of the day I'm going to change over to springs.
