Hi Peter
I will send the cams back this week without fail :-( oooops
Peter Scott wrote on Monday, April 23, 2007 - 09:44 pm:How did you attach the R134 valves?
See pic I used exactly your method for the front (welded boss on the lower part of the shock at an angle..and just retapped the hole on the rears..
Peter Scott wrote on Monday, April 23, 2007 - 09:44 pm:Was it a weld, tap and let the o-ring do the seal? High side , low side valves - does it matter?
I did not use an O'Ring seal, just Loctite super retaining compound (RED) and let it go off for 20 mins before charging.
Peter Scott wrote on Monday, April 23, 2007 - 09:44 pm:That ebay set of gauges - do they all go up to 500 psi? I see they come with the thumbscrew attachment.
The high side gauge will go to 500PSI and as you only need 200 +- 30psi it works great.
Peter Scott wrote on Monday, April 23, 2007 - 09:44 pm:I have a packet of o-rings - but they are imperial- the salesman assured me that they would be fine and don't bother getting metric ones. But I want to get some metric ones- did you source some metric ones?
I got metric o'rings from bearing service, had to order them in though.
Peter Scott wrote on Monday, April 23, 2007 - 09:47 pm:Back to Lynton's problem - do you think the first step is a pump change?
As Dan has said I feel the first step is to check the pressure at the pump outlet.. easiest place is the first acc' next to the 32 active oil tank.
Try here it's a local place for the valves
http://www.jayair.com.au/PartDetails.aspx?PartID=3205
I think that covered it all..
