  Soarer Central * Suspension * Car is bouncing Previous Previous    Next Next
John Loh
SC400 (31)
Wednesday, September 05, 2007 - 07:43 pm, by:  John Loh (Johnathanloh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys! It's been a while since my suspension worked, and i managed to fix it today with more ease than i thought. The moron who owned it before had snipped an air line from the compressor causing the air to escape. Anyway i reconnected it and maybe this is why - Now it bounces up and down like a gangster car whenever i run over a bump. Is this normal? My friend says the damping is screwed. What needs to be done? Another clue: My TEMS and NORMAL/HIGH switch has been is not working. Has my airbag controller been disconnected and causing all of this?
Steve Petkos
Celsior V8
Wednesday, September 05, 2007 - 07:52 pm, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you have been driving around with no air in your bag/s your shocks with be well stuffed !
So basicly your shocks dont work, so your car is riding on a bag of air! = bounce
John Loh
SC400 (31)
Wednesday, September 05, 2007 - 08:05 pm, by:  John Loh (Johnathanloh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aghh... Thats bad. so all that can be done is replacement struts? what about my airbag controller? I don't even know if i have a stock one since i had never been able to adjust the switches, can anyone tell me where i can locate it and check the connections? I forgot to mention that the car has now dropped LOWER since I connected the pump.
Soarer VVTi
Thursday, September 06, 2007 - 06:35 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yup the struts are definitely gone.
JunkFilterer
Thursday, September 06, 2007 - 10:12 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
John Loh
SC400 (31)
Friday, September 07, 2007 - 01:56 am, by:  John Loh (Johnathanloh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I disconnected the hose that i connected in the beginning, now my car is not sitting on its wheels and is raised to normal height. The ride quality is very loose (sways a LOT during turns) but at least it doesn't bounce. Why would this be the case? The hose i disconnected was sucking air into the compressor through a filter (i believe), maybe the filter is clogged and thus the air can't get into the pump. I'm checking it tomorrow, where is the stock air bag controller located? as i said before, my TEMS is not registering on my dash when I toggle the switches. I need to check the connections as it worked for about 3 seconds after i changed the carpet. wierd....
John Loh
SC400 (31)
Sunday, September 09, 2007 - 05:28 pm, by:  John Loh (Johnathanloh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't have an air suspension controller... there are 3 cables loose near where the CD stacker should be. 2 big ones and 1 small one. #@$@!#! I guess it's back to the wreckers. Can someone confirm that this is what i need?
