  SoarerCentral * Suspension * Refurbished UZZ32 Struts? Previous Previous    Next Next
94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Wednesday, November 28, 2007 - 12:35 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was having a search for parts on Ebay and came across these..
http://cgi.ebay.com.au/SOARER-UZZ32-Remanufactured-Accumulators_W0QQitemZ250191179033QQihZ015QQcateg oryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Not affiliated with this person in any way, just thought someone on this forum might be interested after reading the whole debacle about those UZZ32 struts that never seemed to reach that twat in the UK..
Bill Byrnes
Reg: 04-2007
Wednesday, November 28, 2007 - 07:08 pm, by:  Bill Byrnes (Flyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Many thanks Vinh, I've stuck my neck out and purchased them. I'll let you know how I go.
Evan Kaio
Wellington
'91 UZZ31
Reg: 01-2007
Wednesday, November 28, 2007 - 07:17 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1800 hundy. Wow that's cheaper than air struts. Bill I hope the '32 struts workout for you.
Bill Byrnes
Reg: 04-2007
Rating:
Votes: 2 (Vote!)
Friday, December 07, 2007 - 09:03 pm, by:  Bill Byrnes (Flyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After 3 to 4 hours of toil, the re-furbished struts are in. This is by far the best the car has driven in the 5-6 years I've owned it - no harsh ride, no juddering around corners and no pumping at stop lights.
My many thanks go to Peter Taplin who has done excellent work on re-furbishing/re-engineering these struts and has been a total pleasure to deal with.
I cannot recommend these struts highly enough. Every '32 owner should avail him/herself of this service.
Evan Kaio
Wellington
'91 UZZ31
Reg: 01-2007
Saturday, December 08, 2007 - 01:03 am, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bill, Good to see you stuck your neck out, spent some cash and got a result.
Good stuff.
Fred Fuchs
Wellington
UZZ32
Reg: 02-1998
Sunday, January 27, 2008 - 07:54 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did you need use of the pump they mentioned about in the auction?
Robert Carlyon
NSW/SA
UZZ32 GT-L V8 #192
Monday, January 28, 2008 - 08:41 am, by:  Robert Carlyon (Bob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bill, What are you going to do with your old struts?
I would like to send mine to Peter Taplin for refurbishing, but I cant afford the car to be off the road for a couple of weeks. If I could get hold of a set of second handies then I could get them refurbished. My old struts could then be passed on to another 32 owner.
Thanks, Rob
Monday, January 28, 2008 - 05:17 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert,
I gave Tapo a set of 4 Accumulators ! he should have some for exchange.
Steve Latimer
UZZ32
Monday, January 28, 2008 - 08:41 pm, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert,
We do indeed have a complete set of front and rear struts available on a changeover basis.
Please contact either me or Peter Taplin via PM's for more information. You may only need to be off the road for (perhaps) 3-4 hours and the improvement in ride quality will bring an even bigger active grin.
Steve
Steve Latimer
UZZ32
Monday, January 28, 2008 - 08:52 pm, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fred, our re-manufactured '32 suspension accumulators are despatched already charged to the correct pressures, however, we have designed/manufactured a portable recharge/pressure checking unit which is available to those in the '32 community who wish to perform an annual "check-up".
Similarly, the ABS/TRC brake accumulators that we have re-manufactured are also pre-charged, and may be checked/re-pressurised at a later date as required.
Any queries, please contact me (or Peter Taplin)
Cheers Steve
Fred Fuchs
Wellington
UZZ32
Reg: 02-1998
Tuesday, January 29, 2008 - 03:54 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Steve,
just got off the phone with Peter.Im going to get the struts cleaned off tomorrow to check for oil leakage before getting the accumulators.
Quite keen on feeling this new ride capability that i never knew my car had.
Fred
Robert Carlyon
NSW/SA
UZZ32 GT-L V8 #192
Tuesday, January 29, 2008 - 07:30 pm, by:  Robert Carlyon (Bob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steve,
PM sent.
Steve Latimer
UZZ32
Wednesday, January 30, 2008 - 08:46 am, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert,
PM replied
Bill Byrnes
Reg: 04-2007
Wednesday, January 30, 2008 - 02:20 pm, by:  Bill Byrnes (Flyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apologies guys, I have been out of town for a bit.
My struts were on exchange basis with Peter T, so I have none to spare.
The ride/handling improvement is superb - I'm still smiling.
Robert Carlyon
NSW/SA
UZZ32 GT-L V8 #192
Wednesday, January 30, 2008 - 06:09 pm, by:  Robert Carlyon (Bob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problem Bill, Steve has sent me some very comprehensive information and I now know that exchange is OK.
