  Soarer Central * Suspension * SUS Diagnostic codes? Previous Previous    Next Next
Andrew La'Brooy
UZZ31 Soarer GT-L
Reg: 06-2007
Saturday, February 02, 2008 - 04:17 pm, by:  Andrew La'Brooy (Andyttr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone know where I can find out what the diagnostic codes are for the air suspension computer in the UZZ31?
I ran the diagnostics connecting Tc and E1 and got the codes to display on the data screen in the dash.
It shows SUS NG, 11, 12, 13, 73. I get the feeling it has something to do with the aftermarket height controller intercepting signals, but i'd like to know for sure.
Thanks,
Andy
Hays Sleiman
Reg: 11-2009
Thursday, November 07, 2013 - 07:22 am, by:  Hays Sleiman (Hays1530) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Andrew, did you ever end up figuring those numbers out? I'm getting the same codes and this is the only thread that comes up in a search for them...Cheers
Paul Drane
Monday, March 20, 2017 - 07:15 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dragging an old post up, found these english translations for suspension codes for a friend, thought I would share here in case some one needs them.
http://alflash.com.ua/Suscodes.htm
