  Soarer Central * Suspension * Question about lowering and bushes Previous Previous    Next Next
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Friday, February 29, 2008 - 02:58 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It occured to me that since when new rubber control arm bushes are installed, the car needs to be sitting at ride height when the bushes are tightened...wouldn't it also stand to reason that lowering the car without loosening them off first and retightening at the new ride height, be a cause of accelerated failure?
Mustafa Akgul
ToyoPartsMan
Friday, February 29, 2008 - 10:22 am, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not really cause when the suspension is at full drop (on jack) and when its sitting on the road is a big difference where as when car is lowered by 2 or so inches wouldnt make so much as a difference.
