  Soarer Central * Suspension * 4 Wheel Steering Fault Previous Previous    Next Next
John Lucas
NORTH ISLAND
V8 GT-L UZZ32
Monday, May 26, 2008 - 12:04 pm, by:  John Lucas (Johnl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can any of the Active owners tell me how to clear a 4WS fault code. I have tried the dome fuse which cleared the ABS & TRAC faults but not the 4WS. Thanks
Soarer Limited UZZ31 & Soarer 3.0GT JZZ31
Monday, May 26, 2008 - 04:32 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm I wouldn't have a clue but Im sure one of the Australian 32 Goo Roo's will be along soon and have some usable advise.
By the way, I'm Still keen to check out your UZZ32 once you get that sorted and Ive got my new UZZ31 up to my standard to show. Plenty of time!
John Lucas
NORTH ISLAND
V8 GT-L UZZ32
Monday, May 26, 2008 - 06:12 pm, by:  John Lucas (Johnl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Mike. I'm going to be away alot over the winter( the joys of semi-retirement) but give me a call when it suits. Your 31 will be quite a beast when its finished.
Monday, May 26, 2008 - 06:44 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah no problem John, definitely the way to spend time while in the NZ winter period. :-)
Thanks, I'm after keeping it subtle and mostly factory whilst increasing its performance and abilities, but still retaining its smoothness and factory feel.
Personally I Can't stand to make it too far from how it was produced by Toyota originally, Just going to improve on what they did so well to my taste. Will take time but by summer I'm confident it will be 99% complete.
Monday, June 02, 2008 - 02:28 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
John, Have you had any luck with sorting out this issue?
John Lucas
NORTH ISLAND
V8 GT-L UZZ32
Tuesday, June 03, 2008 - 06:42 pm, by:  John Lucas (Johnl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mike, Problem solved but I don't know what finally fixed it. I have just finished fitting an alarm and when I fired it up all the fault codes had cleared and so far its running like a dream.
Tuesday, June 03, 2008 - 06:52 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah well thats good to hear, lets hope it was just a one off bad day the ECU/Sensor was having and nothing more.
Still be ideal to keep and eye on it of course.
