Sunday, June 15, 2008 - 06:33 pm, by: David Goldthorpe(Sprocket82)
My original problem was that the air-struts on the right side of my car were sitting about 25mm lower than those on the left. I use an ASG-63x height controller, which was already installed when I bought the car - this didn't seem able to correct the imbalance. Adjusting the height sensor rods didn't seem to make any difference so after searching through the forum, I found a few guys that had experienced the same problem and asked for their help. I was advised by Blaine Hanson to disconnect the aftermarket controller, and adjust the rods with just the factory suspension computer connected. After spending most of thisafternoon doing this, I had left and right set up evenly, and proceeded to reconnect the aftermarket controller. A big thanks to Blaine for his advise (checkout his website if you haven't seen it: http://www.soarerv8.com/) So the ASG-63x has 4 height settings: the first I use for normal driving. The second mode is for highway cruising and is automatically activated after exceeding 90km/h. The car sits almost perfect in Mode 1 (within 5mm of each other) but if I put it into Mode 2, the left side sits 10-15mm lower than the right. I'm wondering if I should just be happy with the result or keep working at it until both modes are balanced?
Monday, November 16, 2009 - 05:04 pm, by: Joe Russell(Joe_r)
I'm having this problem just now, only recently started. I've had previous problems with my height controller, car bottoming out etc, and I ended up re-soldering some of the internals. Now I think I'll replace most of them and see what that does... Wish me luck!
