Tuesday, October 14, 2008 - 03:28 pm, by: David Goldthorpe(Sprocket82)
I've already purchased a set of LOW Kings and Supra Bilsteins but just trying to work out what other parts I need.
The first diagram is the rear setup on a UZZ30. I'm guessing what I need from here is the top support (48750), the spring insulator (48257), the spring bumper (48341) but not the shock cap (48553).
The second diagram is the front setup on a UZZ30. I'm assuming I need all but the spring and shock from here.
So does this sound correct and if so what are my chances of getting parts for all 4 corners 2nd hand?
Tuesday, October 14, 2008 - 03:41 pm, by: Matt Petersen(Mattmannz)
I sold the set of KYB's with stock springs that I removed from my UZZ30 for $200NZ. Easiest way is prolly to get a set of worn out stock shocks and springs from someone who has fitted coilovers.
Tuesday, October 14, 2008 - 04:17 pm, by: Andrew Meiers(Acmtt)
I have a full set that came off my wreck for $200. Bolt directly in and are in good working order. Just disconnect the air suspension computer after fitting and away you go.
Monday, December 01, 2008 - 03:30 pm, by: David Goldthorpe(Sprocket82)
OK, I am now being told by my mechanic that the yellow Supra bilsteins in the photo above can't be used on my Soarer because the spring height would be way out and only JZA80 springs will fit that strut. I was told by Castle Hill Toyota that these would fit fine so just wondering has anyone else here used them or have I bought something completely useless to me??
Tuesday, December 02, 2008 - 02:01 am, by: Avin Luther(Lex_luther)
i have them in my UZZ31. But yes i needed a Supra King spring on one end of the car (pretty sure it was the rears that are different but cant be certain now). The Struts DO fit.
Daniel Lee Goo Roo Victoria Soarer GT Limited UZZ31 V8
Thursday, December 11, 2008 - 07:51 pm, by: David Goldthorpe(Sprocket82)
Recently purchased a set of JZA80 top mounts from a member of supraforums.com.au to use with the yellow JZA80 bilsteins in the photo above. However, the end of the strut rod is too small for the opening in the top mount and does not fit in firmly as I expect it should.
I've asked James at Castle Hill Toyota (where I bought the struts) why they don't fit and he said to ask you guys!
