  Soarer Central * Suspension * Replacing diff centre Previous Previous    Next Next
Shane Sartori
wa
Reg: 12-2007
Thursday, December 25, 2008 - 02:31 am, by:  Shane Sartori (Kingmoron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i would like to replace the lsd or locker diff (unsure what it is in it) into my other car. I can just replace the centre cant I? i looked at the other threads and they pretty much say just have a look at it and it will make sense. is there anything i need to know? i almost forgot but ill get some diff oil before i pull my cars apart.
Shane Sartori
wa
Reg: 12-2007
Thursday, December 25, 2008 - 02:37 am, by:  Shane Sartori (Kingmoron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i dont know much, but would swapping the whole diff over be easier? :-)
Michael Keen
Reg: 10-2007
Thursday, December 25, 2008 - 08:36 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it not that simple it you must know what you are doing to setup a diff. you must get the contact with the crown and pinion just right other wise it just it self.
i recomend just changing the full diff out.. then you wont need to even change the oil, but it is recommend
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Thursday, December 25, 2008 - 09:20 am, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Changing the entire diff assembly is sooooo much easier than swapping the centres over!
Shane Sartori
wa
Reg: 12-2007
Thursday, December 25, 2008 - 09:51 am, by:  Shane Sartori (Kingmoron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hah ok cool, because i saw the thread last night of someone changing the whole diff out and it looked pretty simple. glad i thought of that :-) thanks guys
