Tuesday, March 03, 2009 - 11:47 am, by: Nandu Jay(Nandu)
Hi
can`t get my active to do the dance anymore or more importantly i can`t do a bleed. i`ve been flicking the boot switch 9 times with the diagnostic terminals bridged and nothing happens.
I used to hear a significant noise on the pump and then fluid would shoot out to do a proper bleed.
i don`t have any error codes either
does anyone know what to check or where to look first..
Tuesday, March 31, 2009 - 03:06 pm, by: Allex Mendis(Alxm)
Nandu Jay was working on this car for me while I was overseas. I would like to provide a bit more info hoping someone out there can help.
We had the struts filled with gas and the suspension was working fine for the first time in a very long time. A couple of weeks after that the suspension stopped working intermittently. The suspension would lower completely and then raise all by itself. From this point on we have not been able to do the 'suspension dance' by flicking the on/off switch.
Error code was SUS 51. We found the suspension pump was leaking so we pulled it apart and rebuilt it. Since then we have not seen any errors come up on the dash and we see 'SUS OK'.
Since suspension is NOT turning on at all we believe the problem is electronic, so either a sensor or the suspension ECU could be faulty. We can not confirm this without any spares.
We will be grateful if anyone in Sydney with a UZZ32 is willing to lend their suspension ECU for a quick test. We have not had any luck finding one at a wrecker. Otherwise if anyone know where we can find one please let us know.
If anyone has any other ideas please let us know. Thanks in advance.
