  Soarer Central * Suspension * Opinions on wheel offsets Previous Previous    Next Next
Open in new windowArchive through May 19, 2009Lawrence Ostle25
Chan Huynh
Reg: 12-2007
Tuesday, May 19, 2009 - 03:42 pm, by:  Chan Huynh (Curfew89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the wisdom everyone, I'll just stick to the soarer & supra wheels I have now for the time being. Tramlining is one thing I'd hate especially if i want a quiet drive home along the freeway.
In terms of bushes, is there one product that I can rely on and trust if I need to replace them?
Spencer Cameron
JZZ30 (converted Manual)
Reg: 04-2008
Tuesday, May 19, 2009 - 04:20 pm, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chan Huynh wrote on Tuesday, May 19, 2009 - 03:42 pm:
I'd suggest Original or VFT bushes for you Chan. Probably lean more towards the VFT.
http://vftbushes.com/
V8 Ltd manual
Tuesday, May 19, 2009 - 06:16 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
quote:
Wow.. Just wow.. Defensive much?
No, just having the usual problems communicating with the barely literate. Keep practising your posting though.
Spencer Cameron
Reg: 04-2008
Tuesday, May 19, 2009 - 06:36 pm, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry in advance Mods..
Barely literate? Really, do you think that's the reason? Are you sure its not your inflated sense of self worth obscuring your view of reality? Perhaps its because your head has become so deeply embedded within your own @ss that you can no long interpret your own BS, let alone anything anyone else might have to say?
Really, really sorry Mods..
V8 Ltd manual
Tuesday, May 19, 2009 - 06:40 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Quite sure, thank you.
The mods are doing fine, by the way
Wednesday, May 20, 2009 - 06:45 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Awesome debating skills guys...
Matt Petersen
NA
Reg: 01-2008
Wednesday, May 20, 2009 - 09:12 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mass debate even.
Spencer Cameron
Reg: 04-2008
Wednesday, May 20, 2009 - 12:47 pm, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sigh, someone had to say it..
Matt Petersen
NA
Reg: 01-2008
Wednesday, May 20, 2009 - 05:20 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rather my comment than the tripe between you and David.
