Sunday, June 14, 2009 - 06:09 pm, by: Spencer Cameron(Switchio)
If its the strut your talking about Adam its pretty straight forward. Once you've got the wheel off, loosen the bolts on the inside of the bottom arm and remove the bolt of the inside of the top one. Undo the bolts/nuts top and bottom on the strut then u can push the arms out of the way to remove the strut. Hope that helps.
