Thursday, July 16, 2009 - 09:30 pm, by: Troy Baker(Sincity)
When I bought my 32 the suspension was leaking, I had the rams rebuilt (Seals replaced). Since then the passenger front has always sunk if the car was parked for a while. Also the passenger front wheel will bottom out it seems and hit the inside of the guard when I hit a bump or gully too fast, usually only at 80km/h plus.
I've searched all the 32 suspension threads but can't find one the same.
When I run the test the front passenger side is always lower than the rest of the wheels. When I check for error codes I get "NG".
I'm also not sure if any mechanic in Perth will know how to fix it.
Saturday, July 18, 2009 - 11:50 pm, by: Michael Crimp(Zen1953)
Peter Taplin does an exchange rebuild and any knowledgable mechanic should be able to fit them My local mechanic did mine without any diagrams or instructions. I strongly recommend giving the mechanic a full set of instructions. It is possible that the problem one is warped or faulty. GL
