  Soarer Central * Suspension * UZZ32 struts Previous Previous    Next Next
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Monday, September 21, 2009 - 12:24 am, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've found a strut for my UZZ32. Ьore accurately, I've found a parts of them.
So, I would like to know, first of all, is this really UZZ32 part?
And I gues it is accumulator, isn't it? Or not?
Or this part have to relations with UZZ32?
Monday, September 21, 2009 - 07:56 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is this some kind of bait? Thats just a bog standard shock absorber. Might be the right one for a Soarer, might not be - but it sure ain't a UZZ32 strut.
Jeff Harper
UZZ32 Active V8
Tuesday, September 22, 2009 - 08:26 pm, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No mate, nothing like it.
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Tuesday, October 20, 2009 - 03:08 am, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks.
I guess I won't multiply new threads and just ask here.
I'd found a hydraulic specialist and given my struts to him. And I really believe my struts will be done in a couple of days, but....
They are out of nitrogen. And the guy don't have any tools to regas them and don't know, what to do. He suggested to make a new holes and to insert there new valves. I've tried to find any information about regas, and found nothing. So, is there any ways to solve the problem?
Dave Hart
Waikato
UZZ32
Tuesday, October 20, 2009 - 06:20 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try looking on this site Yuri.
http://planetsoarer.com/
Daryl Demarte
IS300 & UZZ32
Tuesday, October 20, 2009 - 06:32 pm, by:  Daryl Demarte (Helieng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yuri,
You could try doing this. I have done my own accumulators, easy to check and adjust pressures if necessary, also can pull apart easily.
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Wednesday, October 21, 2009 - 02:42 am, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool. Thanks. I'll try
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Friday, November 06, 2009 - 06:01 am, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello again.
Finally the guy has rebuilt struts for my (At least he demand so).
But he figured out a problem that suspension fluid is not coming into the struts. He told my he thinks it's a problem with the pump and he doesn't know how to fix it.
That's all he told me by phone today.
So if this so, does anybody knows something about the pump repair. Or maybe he just installed the struts incorrectly?
Dave Hart
Waikato
UZZ32
Friday, November 06, 2009 - 07:34 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As I said previously Yuri, it's all in 'Planetsoarer'
