  Soarer Central * Suspension * Aftermarket urethane or polyurethane engine and trans mounts Previous Previous    Next Next
Neil Mystery
Ontario
Reg: 06-2008
Sunday, October 04, 2009 - 03:13 pm, by:  Neil Mystery (92blacktt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I have a 1jz-r154 soarer and am looking for urethane trans and engine mounts.
Anyone know where I can get these? Will any of the mounts made for MKIV or MKIII Supras work? Because those are the only ones available in Canada from the aftermarket.
Thanks,
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Monday, October 05, 2009 - 12:02 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've heard of people taking the actual existing mount to a place who deals with polyurethane and asking them to fill it, and then they drill holes through it, more holes, the softer the mount.
I'll see if i can find links.. (they did this and saved hundreds in some cases)
http://martybugs.net/magna/mount.cgi
http://martybugs.net/Pintara/mount.cgi
4.0GT UZZ30
Tuesday, October 06, 2009 - 02:46 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aiden Cheese wrote on Monday, October 05, 2009 - 12:02 pm:
Same here, it can in many cases be a cheaper and better alternative. I do suggest looking into that.
