  Soarer Central * Suspension * Location of active suspension ecu Previous Previous    Next Next
Jethro Sims
Uzz32
Reg: 05-2009
Friday, October 30, 2009 - 06:36 pm, by:  Jethro Sims (Jethro_sims) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Need to know where the active suspension ecu is so i can check the plugs. Also does anyone know of the list of diagnostic fault codes (example-55,61). I have sus-55,61 fault codes on dash.
Michael Crimp
QUEENSLAND
V8 UZZ32
Reg: 06-2008
Wednesday, November 04, 2009 - 12:11 am, by:  Michael Crimp (Zen1953) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi,
There is a list of codes in several places including Planet Soarer. Good luck
Victoria (The Nazi State)
Active V8 and a Factory Manual XF.
Sunday, November 22, 2009 - 12:59 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And the ecu is behind the passenger side rear seat side trim, below the fuel pump ecu.
