Saturday, November 21, 2009 - 04:38 pm, by: Andrew Eramo(Remuface)
Hey guys,
I didn't think this was true when I heard it, but a friend told me that somewhere in my soarer there was a switch or button that could swap my suspension between sports suspension and a softer suspension.. He said they were in all soarers.. I didn't believe it, but I had to ask because if it's true then I'm pretty happy (fix bumpy ride).
Saturday, November 21, 2009 - 05:08 pm, by: Marc Hoffmann(Rushed)
not all soarers got tems, but most did.
pop the bonnet and look at the strut tops, it should say tems on the covers and have some wires going into them.
if so, flick the econ switch in the car to change the stiffness.
most noticable if you try a hard launch with it set to econ it will launch much better than if in power, as the car gets better weight transfer to the back wheels (dont forget to switch back to power after you are off the line)
there is also a "track day jumper" for even stiffer suspension, search and ye shal find it.
Saturday, November 21, 2009 - 05:20 pm, by: Andrew Eramo(Remuface)
I had a look under my bonnet and was wrapped to find that I do have tems..
This econ switch you talk about.. I'm not too sure where that is? is that the button near the gear stick where it says: Normal, ECT, Power? If not I have no idea where the econ switch is..
Saturday, November 21, 2009 - 07:05 pm, by: Marc Hoffmann(Rushed)
yeah that switch, i tried to think what it said without going out in the rain to the carhold... and went with the std "econ/power" most autos have haha!
Ian Johnston Goo Roo South Australia UZZ30 GT 4.0, UZZ31, BMW R1150R
Saturday, November 21, 2009 - 07:15 pm, by: Ian Johnston(Ted)
The econ switch has nothing to do with the suspension. It just changes the shift rpm of the gears. If you have TEMS, the switches will be in front of the gear lever. I think the TT TEMS is different to the V8 TEMS. The V8 can change suspension height, as well as firmness(2 switches) The TT only changes the firmness.
Saturday, November 21, 2009 - 10:12 pm, by: Matchy Loi(Ftk148)
I'm pretty sure it does both, (change rpm and suspension settings) because I don't have a 'TEMS switch' but I do have TEMS.. I only have the pwr/normal switch.
Sunday, November 22, 2009 - 09:45 pm, by: Andrew Eramo(Remuface)
Matchy Loi wrote on Saturday, November 21, 2009 - 10:12 pm:
Either way, look it up.
so what your saying is when i put it on 'power' it also changes the suspension in the TT??
Monday, November 23, 2009 - 12:08 am, by: Ben Kelly(Ace)
i think its actually a 'test' mode james, the verdict may be out on whether this is a good way to ride around town full time (?). correct me if im wrong
