Thread |
Last Poster |
Posts |
Pages |
 | KSport coilovers | Dave Cazes | 4 | 1 |
 | HSD TT Coilover Suspension | Damian Ware | 23 | 1 |
 | Quality tyres in Sydney | Matthew Sharpe | 3 | 1 |
 | Ideal drag wheel's tyre's? | Marc Hoffmann | 8 | 1 |
 | Sway bar measurements | Nathan Hlad | 15 | 1 |
 | TEMS Suspension Warning? | Boris Siljanoski | 3 | 1 |
 | Post pics of your lowered TT | Marc Hoffmann | 26 | 1 |
 | TEMS | David Kim | 4 | 1 |
 | Steering Wheel Off Center to Stay Straight (After Accident) | Matthew Tai | 7 | 1 |
 | Sway bar | Phil Gibson | 31 | 2 |
 | I want to remove my coils | Nathan Machin | 6 | 1 |
 | New wheel offsets. | Matthew Sharpe | 4 | 1 |
 | Suspension Gear - What's it Worth? | David Goldthorpe | 26 | 1 |
 | Front LCA Bushes measurement | Steve Latimer | 1 | 1 |
 | Interesting - have a look at this lovely soarer | Nathan Machin | 18 | 1 |
 | Sideshaft play in diff? | Austen Menze | 9 | 1 |
 | UZZ32 Suspension and 4WS problems | Dan McColl | 20 | 1 |
 | Spacers? | Austen Menze | 2 | 1 |
 | Lowered Pedders Springs | Trent McKinnon | 14 | 1 |
 | Celsior LSD into v8 soarer ? | Jeff Smith | 4 | 1 |
 | Diff cover removal | Austen Menze | 3 | 1 |
 | Replica wheels, how to tell ? | Aaron Mead | 8 | 1 |
 | Wheel alignment printout | Austen Menze | 7 | 1 |
 | What strut tops are interchangeable onto V8s- TT Jzz30 Jz80 etc | James Lamont | 3 | 1 |
 | Te37 +20 or +40? | Ryan McDonough | 7 | 1 |
 | Longer Wheel Studs, where to buy? | Matthew Sharpe | 8 | 1 |
 | How much adjustment in stock suspension uzz30? | Ian Johnston | 2 | 1 |
 | Trouble getting bottom strut bolt off Any thoughts?... | David Henderson | 6 | 1 |
 | New 19" mags and looking at "low" king srpings, couple qustions... | David Barnes | 6 | 1 |
 | Standard Supra JZA80 coilovers on Soarer V8? | David Barnes | 4 | 1 |
 | Air sus finally on its last legs, any thoughts? | David Eberhart | 11 | 1 |
 | Soarer airbags on Celsior? | Paul Drane | 2 | 1 |
 | Problem with main spring height adjusting nut jammed on Tein HA's | Matt Petersen | 4 | 1 |
 | Lower Control Arm front bushes issues... | Daniel Castro | 9 | 1 |
 | HSD coilover issues.. | Phil Gibson | 27 | 1 |
 | Rear strut brace | Ben Lipman | 3 | 1 |
 | Another question regarding Wheels and offset | Steven Anderson | 11 | 1 |
 | 5-Spoke Wheels... post them up! | James Cahir | 160 | 7 |
 | Airstrut related part identification help.... | Razvan Petrescu | 8 | 1 |
 | V8 with TEMS - diagnostics have been run, here are my findings | Glen Muller | 5 | 1 |
 | Ride Confort of Lowered Springs | Nathan Machin | 4 | 1 |
 | Is this a Torsen diff? | Peter Nitschke | 30 | 2 |
 | Superpro Suspension bushes for sale here, please look | Aaron Casey | 21 | 1 |
 | Soarer Non-Power Steering? | Robert Cranfield | 14 | 1 |
 | Coilovers? | Warren Moore | 12 | 1 |
 | Loud Banging noises!!! | Anthony Wah Day | 8 | 1 |
 | Honda Accord Euro 17 inch wheels - they should fit right? | David Henderson | 4 | 1 |
 | Searching for Wheel Options | Murray Lund | 15 | 1 |
 | Taller Diff Gears | Robert Cranfield | 5 | 1 |
 | Enkei NT03's | Matt Petersen | 8 | 1 |
 | SSR Vienna Dish | Dean Smyth | 15 | 1 |
 | Opinions on Falken "FK 452" tyres | Matthew Sharpe | 21 | 1 |
 | 3.9 ratio LSD in a TT | Costa Tsimiklis | 19 | 1 |
 | Air Suspenion Diagnostics | Robert Cranfield | 38 | 2 |
 | Clunking while turning | Peter Nitschke | 5 | 1 |
 | Soarer shocks | Matthew Sharpe | 7 | 1 |
 | Cheapish Ebay Coilovers | Chris Ryan | 1 | 1 |
 | TT steering bushes | Austen Menze | 8 | 1 |
 | Air struts again...will i stay or will i go... | Ben Kelly | 5 | 1 |
 | Every Rose Has its Thorn | Rowan Mutu | 3 | 1 |
 | Replacing ball joint boots/ check ball joints | David Henderson | 6 | 1 |
 | Need help and advice | Terry Bishop | 5 | 1 |
 | Steering Rack | Daniel Driscoll | 1 | 1 |
 | Rebuilding TEMS airbags?? | Andrew Duaso | 6 | 1 |
 | Improve handling on air suspension? | Ali Saeed | 7 | 1 |
 | Replaced air bag suspension... But now have error msg's | Andrew Duaso | 10 | 1 |
 | Will these rims fit? | Ali Saeed | 40 | 2 |
 | Steering rack | Jamie Richards | 2 | 1 |
 | Steering rack excessive play!!! | David Tra | 5 | 1 |
 | Rear Air Suspension-bouncing to one side | Evan Kaio | 5 | 1 |
 | Potential new wheels... opinions please! | Jamie Richards | 20 | 1 |
 | Drag-oriented suspension | Steve Oleksak | 25 | 1 |
 | Lowering springs with standard shocks, mobile pogo stick? | Dave Cazes | 8 | 1 |
 | LSD for 1998 LS400 | Paul Rachow | 1 | 1 |
 | How hot does a torsen diff get? | Ben Lipman | 13 | 1 |
 | Diy diff fitting?? | Costa Tsimiklis | 12 | 1 |
 | Which oil for TRD LSD? | Mike Beck | 9 | 1 |
 | Suspension woes (Rear Upper Control arm) | David Tra | 15 | 1 |
 | Can u tow / push a car with no diff in it? | Shane Sartori | 7 | 1 |
 | LSD Diff replacement for a 91 auto | Peter Angelopoulos | 2 | 1 |
 | Diff gone? | Gary Rollason | 15 | 1 |
 | Tyre wear | Garth Williams | 7 | 1 |
 | Scraping or clunking on my TT when turning right | Narvey Vilaythong | 7 | 1 |
 | Tems suspension | Marc Hoffmann | 2 | 1 |
 | Swaps for rims maybe? 18x7.5 BSA AU-229 | Kevin Trac | 4 | 1 |
 | What's the problem? | Md Adib Bahzi Majid | 17 | 1 |
 | Switching between suspensions | Ben Kelly | 13 | 1 |
 | Location of active suspension ecu | Dan McColl | 3 | 1 |
 | Tire gurus help required. | Steve Latimer | 2 | 1 |
 | Airbag problem almost fixed | Joe Russell | 3 | 1 |
 | Limited suspension swap | Ron Bassett | 28 | 1 |
 | BOOM BOOM POW! | Peter Nitschke | 3 | 1 |
 | Aristo springs for Soarer? | Luke Hoban | 7 | 1 |
 | UZZ32 struts | Dave Hart | 9 | 1 |
 | Stock TT/NA spring rates? | Matthew Tai | 1 | 1 |
 | Bushes? | Kevin Trac | 5 | 1 |
 | UZZ31 Airbags | Daniel Lee | 23 | 1 |
 | Drivers Air Strut - replaced 2 months ago and now dead | Christian Somerville | 7 | 1 |
 | Celsior Air Suspension Issue | Joshua Baldwin | 3 | 1 |
 | Looking for a picture of a soarer with standard jza80 wheels | Matthew Sharpe | 13 | 1 |
 | Camber | Spencer Cameron | 47 | 2 |
 | Which offset combination would be best? | Steven Anderson | 13 | 1 |
 | Ball Joint Seperator | David Henderson | 10 | 1 |
 | Drivers side lower control arm | Daniel Salt | 17 | 1 |
 | Soarer Locked Diff / Spool | Costa Tsimiklis | 1 | 1 |
 | Rims Gallery | Nathan Machin | 134 | 6 |
 | New lower control arm and ball joint!!! help !!!! | Chris Ryan | 11 | 1 |
 | Which Wheels | Matt Fairless | 29 | 1 |
 | Active suspension test not working | Jethro Sims | 1 | 1 |
 | Front passangerside wheel bearing gone | Jacob Serifo | 8 | 1 |
 | Active suspension height question | Andrew Duaso | 2 | 1 |
 | Soarer Diff Q's? | Phil Gibson | 15 | 1 |
 | JZA80 strut mount into UZZ31 | David Goldthorpe | 2 | 1 |
 | Lowering in VIctoria | Andrew Duaso | 23 | 1 |
 | Trd sway bars | Hakan Pasha | 3 | 1 |
 | Question about coilovers? | Cihan Aday | 10 | 1 |
 | V8 drivers with coilovers - in here please! | Md Adib Bahzi Majid | 14 | 1 |
 | Coilovers for v8...do i need pillow mounts? | Md Adib Bahzi Majid | 11 | 1 |
 | Pillow Mounts..? | Md Adib Bahzi Majid | 5 | 1 |
 | What are your opinions? | George Dertadian | 15 | 1 |
 | Lower control arm V8 / TT | Michael Brown | 1 | 1 |
 | UZZ31 TERM airbag. Need help URGENT | Barry Burr | 8 | 1 |
 | Wheels size dilemma | Prem Ananth Ganesh | 23 | 1 |
 | Aftermarket urethane or polyurethane engine and trans mounts | Mike Beck | 3 | 1 |
 | Soarer or Supra parts - help please | Steve Gorman | 3 | 1 |
 | Rear upper conrol arm.. | Spencer Cameron | 1 | 1 |
 | Shredded Ball Joint ... | Daniel Lee | 2 | 1 |
 | New crown wheel for my diff | Dinesh Singh | 4 | 1 |
 | Strut Brace | Hakan Pasha | 16 | 1 |
 | SUPER STREETS AND EDFC | David Samuel | 9 | 1 |
 | Anyone heard/know anything about these? | Daniel Lee | 27 | 1 |
 | Best suspension set up for under $3000?? | Dave Cazes | 40 | 2 |
 | What offset and tyre size? | David Vaughan | 31 | 2 |
 | King Springs | Dave Cazes | 2 | 1 |
 | Now What ?? | Nathan Hlad | 13 | 1 |
 | Lowered Springs | Matthew Sharpe | 2 | 1 |
 | Need HELP from all the TYRE Specialist PLEASE | Michael Crimp | 31 | 2 |
 | JZA70 | Masato Hara | 5 | 1 |
 | Is this an ok size wheel????? | Matthew Sharpe | 21 | 1 |
 | Part number needed, Right Front strut air line (driver side) | David Goldthorpe | 2 | 1 |
 | Replacing lh air strut question | Jack Oliver | 8 | 1 |
 | Why you shouldn’t lower the rear of your car (PART 2) | Ben Lipman | 2 | 1 |
 | Just wondering.. | Spencer Cameron | 4 | 1 |
 | Identifying diff | Ali Saeed | 6 | 1 |
 | JZA70 MZ20 Coilovers | Dave Cazes | 6 | 1 |
 | New tyres stuffed | Miles Baker | 9 | 1 |
 | UZZ31 air suspension height.. | Md Adib Bahzi Majid | 13 | 1 |
 | Which tein's ?? | Dave Cazes | 18 | 1 |
 | New Airbag Suspension Fitment Price | Ali Saeed | 19 | 1 |
 | SC400/UZZ Springs compatible with SC300/JZZ? | Ian Johnston | 5 | 1 |
 | What offset do I need??? | Vinh Bui | 23 | 1 |
 | Strut rubber boot?? | Ian Johnston | 2 | 1 |
 | Jzz30 springs same as jzz31?? | Dave Cazes | 4 | 1 |
 | Digital Height Controller Help | Michael Toet | 8 | 1 |
 | Active suspension troubles | Steve Latimer | 4 | 1 |
 | Has anyone had experience with lowered coil springs?????? | David Barnes | 5 | 1 |
 | Supra arms into jzz30 | Ben Lipman | 35 | 2 |
 | Diff issues | James Johnson | 10 | 1 |
 | Speedometer | David Vaughan | 5 | 1 |
 | Refinish Chrome Wheels | Matthew Sharpe | 4 | 1 |
 | Field Height Controller English Manual? | Michael Toet | 3 | 1 |
 | 32 Suspension problem | Michael Crimp | 3 | 1 |
 | Taking apart rims for cleaning | Rob Rojo | 7 | 1 |
 | DIY LSD Install? | Scott Wilkes | 3 | 1 |
 | Steering column | Michael Jaballah | 3 | 1 |
 | Rear Wheel Bearings | Daniel Salt | 3 | 1 |
 | Wheel allign UZZ31 Normal, or high setting?? | Evan Kaio | 2 | 1 |
 | HIRO-R M-350 LOWERING SPRINGS | Dave Cazes | 2 | 1 |
 | Lower control arms | Dave Cazes | 10 | 1 |
 | 17" tyre size question | Shane Haverkamp | 10 | 1 |
 | Why you shouldnt lower your car too much- For better handling, read on | Dave Cazes | 84 | 4 |
 | UZZ32 suspension problem | Damian Ware | 7 | 1 |
 | Prices on factory rims resprayed black | James Harris | 4 | 1 |
 | Engineering 9" wide rims | Michael Sinay | 7 | 1 |
 | Peoples opinions on tyres? | Matt Newman | 53 | 2 |
 | Is this cheap | Drew Rechner | 2 | 1 |
 | Crossmember ?? | Nenad Ristovski | 1 | 1 |
 | UZZ31 / UZZ32 front height adjuster rod | Andrew Duaso | 2 | 1 |
 | Can the suspension drop quicker? | Scott Casey | 2 | 1 |
 | So what's with the 20" plus wheels? | Peter Nitschke | 26 | 1 |
 | Sway Bar Linkage | Dave Cazes | 20 | 1 |
 | Suspension for uzz31's | Daniel Lee | 3 | 1 |
 | Rear Suspension Member Cushion... | Fabian Bordon | 3 | 1 |
 | Front left airbag leaking when car is turned off | Jack Oliver | 27 | 1 |
 | Ball Joints | Dave Cazes | 8 | 1 |
 | How to get my suspension light to turn off? | Ben Dornbusch | 3 | 1 |
 | Air Compressor bushes and filter | Michael Toet | 3 | 1 |
 | Suspension questions, Upper balljoints and bushings | Dave Cazes | 2 | 1 |
 | HOW TO CHANGE DIFF OIL? | Warren Day | 8 | 1 |
 | Changing the front suspension | Dave Cazes | 6 | 1 |
 | Rear suspension trailing arms bushes | Dave Cazes | 9 | 1 |
 | Toyota Bushes | Prem Ananth Ganesh | 5 | 1 |
 | Anyone using Maxxis MAV1? | Andrew Ferres | 10 | 1 |
 | Spring seats | Dave Cazes | 2 | 1 |
 | Equivalent Celsior 1990 UCF11 Air Susp Strut part number in LS400 t... | Mark Tierney | 1 | 1 |
 | Do I have a tt lsd? | James Buchan | 12 | 1 |
 | AdCamber Adjusting Pins | Murray Lund | 1 | 1 |
 | Issues with ride qualtiy | George Dertadian | 5 | 1 |
 | Removing Rear Suspension Member... | Dave Cazes | 5 | 1 |
 | Vlamos Steering Rack Bushes | Daniel Clarke | 1 | 1 |
 | Soarer steering rack bushings (47mm or 50mm) | Andrew Meiers | 2 | 1 |
 | Airstruts/springs | Tim Kroek | 3 | 1 |
 | Advice on replacement of airbags | Daniel Lee | 12 | 1 |
 | Cut springs | Chris Round | 9 | 1 |
 | Airbag specialist in Brisbane??? | Daniel Lee | 2 | 1 |
 | Suspension Error - Springs in 31 | Daniel Lee | 3 | 1 |
 | Balljoints and Vlamos Bushes... | Jeff Bedsor | 4 | 1 |
 | Nolathane bushes... ?? | Dave Cazes | 7 | 1 |
 | How do i ?? | Daniel Langridge | 3 | 1 |
 | Uz31 airbag deflated | Jose-Antonio Castill | 13 | 1 |
 | Supsension & Handling Improvement | Chris Prak | 9 | 1 |
 | Opinions on wheel offsets | Matt Petersen | 34 | 2 |
 | Replacing bushes in front control arm | Matthew Werner | 13 | 1 |
 | LR Tyre destroyed - camber and alignment issue | Chris Round | 10 | 1 |
 | Tute on how to change steering rack bushes. | Michael Jaballah | 6 | 1 |
 | Stock Shocks Part Number | Matthew Tai | 4 | 1 |
 | Arnotts air bags. | Michael Jaballah | 3 | 1 |
 | Tt mini spool | Costa Tsimiklis | 4 | 1 |
 | Rear Wheel Bearing Inner & Outer Race... | Fabian Bordon | 7 | 1 |
 | UZZ31 rear end bouncing around ... | Rick Slav | 11 | 1 |
 | Active suspension. UZZ32 | Michael Crimp | 27 | 1 |
 | WOOOOOOOOOOOOOW!!!!!!! | Sean Routledge | 19 | 1 |
 | Jack Stand Location with photos... | Dave Cazes | 5 | 1 |
 | Active suspension dance | Nathan Richardson | 5 | 1 |
 | Rubbing me raw | Dave Cazes | 24 | 1 |
 | New Adjustable Rear Toe arms & traction Rods, Very strong rose join... | Dave Cazes | 29 | 1 |
 | Specs for soarer wheels | Steven Anderson | 6 | 1 |
 | Mx83 torsen in a jzz30 | Phil Gibson | 2 | 1 |
 | Toyota Supra JZA80 torsen B-series LSD | Michael Keen | 6 | 1 |
 | Rooted tyre - opinions | Rainer Fritzsche | 13 | 1 |
 | Help needed! | Ben Lipman | 6 | 1 |
 | What other diffs will fit a JZZ30..? | Sebastian Grant | 18 | 1 |
 | Decision on Bushes | Prem Ananth Ganesh | 12 | 1 |
 | Quote | Dave Cazes | 2 | 1 |
 | Front Wheel Bearing Part No | Prem Ananth Ganesh | 3 | 1 |
 | Sounds driving me crazy..possible wheel bearing?? | Prem Ananth Ganesh | 23 | 1 |
 | Uneven wheel gap-Airbags | Myles Jantzen | 8 | 1 |
 | Comparing 17's to 19's, opinions needed | Dave Cazes | 29 | 2 |
 | Power steering problem | Joe Russell | 4 | 1 |
 | Air suspension wiring... Need help! | Joe Russell | 3 | 1 |
 | UZZ32 suspension doesn`t work | Colin Kirkpatrick | 6 | 1 |
 | Tems struts replacing air shocks | John Loh | 10 | 1 |
 | Help requested setting up coilover ride height etc | Ben Lipman | 22 | 1 |
 | Clunking noise, could be the diff | Sebastian Grant | 35 | 2 |
 | Bilstein shocks installed; 'TEMS Suspension' warning on. | Ron Bassett | 9 | 1 |
 | Suspension Question... or "Help Save My Spine!" | Laz Razmo | 31 | 2 |
 | Suggestions for LSD installation | Daniel Clarke | 2 | 1 |
 | Replacing Tailshaft Donut | Tim Ross | 20 | 1 |
 | Replacing shocks | Antonio Hunt | 10 | 1 |
 | Identfying shocks | Daniel Krinkel | 2 | 1 |
 | Help needed with Lowering and Shockers | Mike Triggs | 5 | 1 |
 | New BBS 17s + questions | Justin Camilleri | 7 | 1 |
 | Steering Rack Bush Replacement | Michael James | 2 | 1 |
 | Slightly bent rear cross-member | David Goldthorpe | 4 | 1 |
 | Changing wheel bearings. | Rich O'neil | 13 | 1 |
 | Is there meant to be a gap between the tie rod ball joint? | Dave Cazes | 9 | 1 |
 | UZZ32 rear RHS sagging | Peter Taplin | 6 | 1 |
 | My Drop | Vincent Fontenot | 20 | 1 |
 | JZX90 Diff into JZZ30-31 ?? | David Tra | 2 | 1 |
 | Steering Problems ... | Oliver Whaites | 10 | 1 |
 | UZZ31 Air Bag / TEMS Suspension seems to have stopped sensing / wor... | John Roberts | 5 | 1 |
 | Propped up air bag suspension. Opinions please? | Mike Beck | 3 | 1 |
 | Tein coilovers | Garth Williams | 15 | 1 |
 | Fitting 275/40/17 drag radials on my Soarer | Dale Holan | 11 | 1 |
 | UZZ32 sus error 51 | Nandu Jay | 2 | 1 |
 | Mini spool | Daniel Clarke | 4 | 1 |
 | SC300 Front Strut bar fit JZZ30 ? | Dave Cazes | 10 | 1 |
 | Ball Joints - What are people doing to repair/replace ? | David Goldthorpe | 4 | 1 |
 | Airbag suspension aftermarkert upgrade kits? | James Clark | 9 | 1 |
 | JZZ30 TT Diff ratio's Manual or Auto .. | Daniel Clarke | 6 | 1 |
 | Replacing TEMS (non air) front struts ? | Jason Munro | 10 | 1 |
 | Aristo/Soarer | Brendan McGannon | 6 | 1 |
 | Will these wheels be alright for the Soarer? .... Hmmmmmmmm | Kane Chan | 8 | 1 |
 | Dont Know Whats Wrong | Peter Nitschke | 4 | 1 |
 | NOOOOOOOOOOOOOOOOO | Michael Keen | 28 | 1 |
 | UZZ31 Steering Rack part number? | James Harris | 6 | 1 |
 | Weld to lock diff | Andrew McKellar | 26 | 1 |
 | Rear Struts | Tim Ross | 18 | 1 |
 | Rear Shocks and Springs | Matthew Sharpe | 2 | 1 |
 | Removing lower strut bolt, bastard won't move | Michael Keen | 9 | 1 |
 | LEXUS SC400/SOARER 4.0 AIR SUSPENSION | David Vaughan | 3 | 1 |
 | Diff Specialists | Daniel Driscoll | 1 | 1 |
 | Tein HA dampener settings | Grant Rowan | 8 | 1 |
 | Stuffed coilovers? | Andrew Meiers | 5 | 1 |
 | Adjustable Air suspension! | Glen Muller | 4 | 1 |
 | Need help with TEMS replacement! | Aaron Grenadier | 4 | 1 |
 | Ford Rims??? | Ron Bassett | 9 | 1 |
 | Replacing bushes | Shane Sartori | 17 | 1 |
 | Help identify this torsen | Shyam Purushothman | 7 | 1 |
 | Replacing diff centre | Shane Sartori | 5 | 1 |
 | Advice re: rebuilding ball joints | Ben Hesketh | 17 | 1 |
 | Coilover options? | Ben Socratous | 2 | 1 |
 | Good rims for big brake upgrade | Mark Donovan | 61 | 3 |
 | Uzz31 Tems suspension compressor | Trev Taun | 5 | 1 |
 | Refurbishing/repainting wheels | Tanat Upatising | 16 | 1 |
 | Replacing rear wheel bearings | Michael Keen | 28 | 1 |
 | Need help with this. | Daniel Clarke | 6 | 1 |
 | Converting UZZ31 to springs - What extra parts do I need? | Alan Chow | 21 | 1 |
 | HELP!!! SOARER'S HEIGHT AT DRIVER SIDE (RHD) IS STUCK AT HIGH HEIGH... | Dave Rose | 14 | 1 |
 | LCA ball joints | Matt Newman | 4 | 1 |
 | Active suspension test mode? | Alex Barbieri | 2 | 1 |
 | SC400 and soarer use same tie rods? | Justin Camilleri | 2 | 1 |
 | How do you take out the front shocks and springs? HELP>.... | Ben Lipman | 6 | 1 |
 | KYB Bump stops | Fabian Bordon | 1 | 1 |
 | Track day TEMS mod | David Ormsby | 19 | 1 |
 | URGENT HELP NEEDED Airbag suspension collapsed | Cliff Field | 4 | 1 |
 | New wheels ! | Scott Wilkes | 3 | 1 |
 | Height controller help? | Robert Pressnell | 3 | 1 |
 | Replacing TEMS struts with non TEMS ones. | Jason Munro | 2 | 1 |
 | TT Tein Issue...Is there somthing im missing? | Kenny Williams | 26 | 1 |
 | Replacing rear air struts | Phil Gibson | 2 | 1 |
 | Teins v Standard shocks | Matt Petersen | 14 | 1 |
 | Bushings, control arms, tie rods etc interchangability? | Dave Cazes | 2 | 1 |
 | Confusing LSD Choices | David Tra | 25 | 1 |
 | What is this? I need a new one! | Karl Baladovciv | 5 | 1 |
 | Has Anyone Fitted Mevotech Control Arms | Josh Brown | 1 | 1 |
 | Power steering? leaking fluid | Matchy Loi | 2 | 1 |
 | WARNING red message "AIR BAG" | Matthew Sharpe | 2 | 1 |
 | How to use TEMS air suspension? | Matthew Sharpe | 9 | 1 |
 | Will these tyre fit | Robert Pressnell | 16 | 1 |
 | Kei Office coilovers need help | Ben Lipman | 14 | 1 |
 | *** NEW OWNER *** STIFF Stock Suspension with Active suspension ... | Daniel Clarke | 5 | 1 |
 | Thinkin' 'bout lowerin' | Matthew Sharpe | 33 | 2 |
 | Front Lower Control Arm Bushes | Andrew Vlamos | 15 | 1 |
 | Diff oil for torsen | Matt Petersen | 2 | 1 |
 | Warning Message - Active Suspension | Dave Hart | 11 | 1 |
 | Need help IDing this Vertex's Wheels! | Vincent Fontenot | 4 | 1 |
 | Different wheel Dia. | Adam Lonergan | 3 | 1 |
 | Does this car have air suspension? | Peter Nitschke | 5 | 1 |
 | Whining Diff... | Fabian Bordon | 3 | 1 |
 | HELP! - Front bushes in Adelaide | Ashley Leach | 42 | 2 |
 | In need of some new wheels! | Rob Rojo | 7 | 1 |
 | Minispool... | Sean Routledge | 15 | 1 |
 | UZZ31 - Entire air suspension completely dead and unresponsive | Scott Casey | 12 | 1 |
 | TRD LSD and lovin it | Josh Brown | 6 | 1 |
 | TEMS suspension adjustablity? | Mark Ribbans | 3 | 1 |
 | Tyre Info | Don Bagnall | 16 | 1 |
 | Mz20 front balljoint | Brendan McGannon | 2 | 1 |
 | BIG TROUBLE! | Daniel Clarke | 3 | 1 |
 | Tems without wiring | Josh Brown | 4 | 1 |
 | New rims/tires | Brendan McGannon | 4 | 1 |
 | Bilstein Hypercoils | Dave Cazes | 18 | 1 |
 | Supra JZA80 shocks and springs | Dave Cazes | 2 | 1 |
 | HKS TEMS controller | James Cahir | 1 | 1 |
 | Noisy air suspension | Ben Kelly | 3 | 1 |
 | Coilovers or Spring Shock Combo. | Dave Cazes | 8 | 1 |
 | Need help with my arms | Matt Petersen | 3 | 1 |
 | Torsen LSD + auto ?? | David Vaughan | 7 | 1 |
 | Suspension Air Pump | Fran Valdivia | 6 | 1 |
 | Noisy suspension | Andrew Magee | 4 | 1 |
 | Stock Wheel Question | Mike Triggs | 6 | 1 |
 | Will this Rim/Tyre combo fit? | Alan Wainwright | 3 | 1 |
 | Resetting springs | Matthew Sharpe | 5 | 1 |
 | What is recommended tyre pressure? | Harry Newman | 17 | 1 |
 | Let down | Andrew Ferres | 6 | 1 |
 | Splitting lca control arm ball joints | Matthew Standage | 7 | 1 |
 | Air Suspension | Chris Papas | 6 | 1 |
 | Model differences???? | Don Bagnall | 4 | 1 |
 | Wheels Not Balanced | Prem Ananth Ganesh | 8 | 1 |
 | Suspension problem. | Sean Routledge | 3 | 1 |
 | TEIN or King/KYB | Matt Petersen | 5 | 1 |
 | Power Steering Hose Replacement (V8) help? | Tim Uhen | 4 | 1 |
 | HELP!!!!! PLEASE!!!!! | Dhanushke Herath | 9 | 1 |
 | Coilovers- Air Force Suspension | Ryan Rankovic | 11 | 1 |
 | V8 Air Strut(s) Question... | Mike Bradberry | 3 | 1 |
 | Suspension contoller wanted | Glen Lomman | 1 | 1 |
 | Who supplies last series springs? | Doran Guthrie | 1 | 1 |
 | Steering rack end boots | Tim Uhen | 7 | 1 |
 | Anything to be wary of? | Don Bagnall | 11 | 1 |
 | Problem with my airbag suspension | Cameron Cuddihy | 5 | 1 |
 | Coilovers. With or without camber tops? | Dave Cazes | 8 | 1 |
 | Wheel Repairs Needed in Sydney | Paul Mainey | 1 | 1 |
 | TEIN FLEX VS HKS HYPERMAX RS | Stephen Lee | 2 | 1 |
 | Standard Shock Replacement options | Don Bagnall | 11 | 1 |
 | Filling up with air | Chris Lock | 3 | 1 |
 | Help with 4WS Error Code | Mario Lentini | 1 | 1 |
 | Do I have TEMS?!?!? | Mario Lentini | 2 | 1 |
 | K-SPORT Coilovers..any good? | Mike Triggs | 7 | 1 |
 | SSR SP1 | Michael Jaballah | 13 | 1 |
 | Heated Springs ? | Anthony Weller | 4 | 1 |
 | DIFF/ CV Joint Question | Matt Petersen | 8 | 1 |
 | Diff Advice needed | Dennis Weglehner | 12 | 1 |
 | King Springs on TEMs? | James Harris | 5 | 1 |
 | Suspention air bag deflated! HELP! | Clare Taylor | 9 | 1 |
 | Diff Ratios?? | Ben Ramos | 1 | 1 |
 | What type of LSD do i have? for factory manual TT.? | Steven Anderson | 23 | 1 |
 | Diff Conversion | Ben Ramos | 3 | 1 |
 | Refurbised Active Suspension squeeking... | Matz Persson | 3 | 1 |
 | Big Problem With Pedders | Michael Crimp | 12 | 1 |
 | How to use? 04455-24051 Power steering overhaul kit | Matchy Loi | 8 | 1 |
 | Absorber controller- is this for TEMS? | Ben Lipman | 2 | 1 |
 | Need instructions for height controller | Bob O'Brien | 2 | 1 |
 | Power Steering connections | Adam Neilson | 1 | 1 |
 | Noise is gone | Scott Casey | 10 | 1 |
 | Having problems finding an lsd | Scott Gates | 10 | 1 |
 | New Front Airbags not performing | Mark Prance | 4 | 1 |
 | Who Needs Air-Bag Suspension??..Lower Than Low [Don't Let This Happ... | George Wells | 4 | 1 |
 | Lowwrering Ltd V8 with R-SPEC Controller | Daniel Lee | 8 | 1 |
 | TYRES.... What Brand ? How much ? How good? | Tim Ross | 17 | 1 |
 | New Bushes Fittings Quote Advice Needed | Razvan Petrescu | 32 | 2 |
 | Height switch broken | Daniel Lee | 2 | 1 |
 | Gemini springs??? | Maurice Diggler | 7 | 1 |
 | Good suspension place in melbourne | Adam Lonergan | 3 | 1 |
 | Diff oil ... | Daniel Clarke | 13 | 1 |
 | Spacers | David Ilba | 14 | 1 |
 | UZZ 32 Active Suspension Pressure Settings. | Ross Gates | 1 | 1 |
 | TEMS for SC400 | Mark Prance | 4 | 1 |
 | Dolce DC12 Wheels - Does anyone have them? | Emille Coniglio | 7 | 1 |
 | Air suspension | John Khanh | 15 | 1 |
 | Cortrol arm and rack bushes | Ben Socratous | 7 | 1 |
 | Jzz and uzz lower control arm difference? | Matthew Sharpe | 21 | 1 |
 | Compressing springs | Avin Luther | 6 | 1 |
 | Reconditioning coilovers | Sokoni Forsythe | 12 | 1 |
 | Does anyone know anything about the grommit bush? | Darryn Dewar | 9 | 1 |
 | Any good Suspension places in Sydney? | John Khanh | 6 | 1 |
 | Anyone with this tire combination | Ben Lipman | 9 | 1 |
 | Air Bag Dying? Help needed... | Matthew Sharpe | 13 | 1 |
 | 9 INCH WIDE RIMS??? | Joe Radisic | 6 | 1 |
 | Post pictures of your Soarers with mesh wheels!!! | Matt Petersen | 35 | 2 |
 | Front brace | Dave Cazes | 3 | 1 |
 | Please tell me what these are | Jose-Antonio Castill | 12 | 1 |
 | Wheel nuts | Jim Burrough | 2 | 1 |
 | Front and rear Bushes and steering arm | Mike Beck | 21 | 1 |
 | Are my Struts Rewted | Peter Nitschke | 4 | 1 |
 | How do i check front ball joints? | Matchy Loi | 7 | 1 |
 | 4 Wheel Steering Fault | Mike Beck | 7 | 1 |
 | Front hubs | Dave Cazes | 2 | 1 |
 | Compare wheels (rims) | Craig Webber | 45 | 2 |
 | Advice on Wheel Nuts left untightened | Peter Nitschke | 9 | 1 |
 | What aftermarket aircompressor is suitable with factory system? | Gregg Holden | 14 | 1 |
 | 17 inch wheels +50 offset | Ben Lipman | 8 | 1 |
 | Wheel allignment | Mustafa Akgul | 5 | 1 |
 | Same size tyres on different size (width) rims. | Ben Hesketh | 5 | 1 |
 | Torsen Diff???? | Ali Yazici | 16 | 1 |
 | Tutorial for rear Bush replacement | Peter Nitschke | 4 | 1 |
 | Squeaking rear suspension. Bushes? | George Funa | 10 | 1 |
 | Airbags are stuffed, wondering what suspension replacements people ... | Steve Davies | 11 | 1 |
 | Shortening a straight rear axle | Miles Baker | 1 | 1 |
 | Bilstein height adjustable struts? | Rich O'neil | 5 | 1 |
 | 16" Toyota Wheels | Dave Cazes | 10 | 1 |
 | Om...wheel problem again, 245/35ZR19 offset 52 | Galo Cheung | 5 | 1 |
 | Advice or help needed on expensive mechanics bill | Matt Petersen | 11 | 1 |
 | My Cars doing something CRAZY!!!!!![Airbag suspension problem] | Nicholas Patterson | 5 | 1 |
 | Perplexing knocking noise from front right | Gregg Holden | 5 | 1 |
 | TEMS Struts | Jake Purches | 33 | 2 |
 | Street tyre recommendations | Matt Petersen | 37 | 2 |
 | CHANGING STEERING RACK BUSHINGS | Dave Rose | 3 | 1 |
 | +35 offset wheels | Jose-Antonio Castill | 36 | 2 |
 | Cannot remove front coilovers (JZZ30) | Mike Thomas | 21 | 1 |
 | CQ Wheel Alignment? | Jeff Bedsor | 3 | 1 |
 | Looking to get new wheelI | Jose-Antonio Castill | 7 | 1 |
 | Adjustable suspension | Matthew Crawford | 20 | 1 |
 | Question for the suspension gurus | Chris Prak | 3 | 1 |
 | Coilovers for JZZ31? | Julia Almond | 6 | 1 |
 | Can front TEMS shocks be repaired? Is it worth the trouble? | Lindsey Swan | 15 | 1 |
 | Sloppy Seconds: uzz31 | Peter Nitschke | 7 | 1 |
 | Thunk in da Trunk | Davin Kemshead | 6 | 1 |
 | Another diff question! | Cameron Spencer | 2 | 1 |
 | Air suspension error 51 | Rich O'neil | 4 | 1 |
 | Another happy customer | Mustafa Akgul | 2 | 1 |
 | JZZ30 GTTL active suspension coming out.. so wtf? | Troy Burtis | 4 | 1 |
 | Air Suspension Mods | Jose-Antonio Castill | 4 | 1 |
 | Which coilover suspension can fit to Uzz31(air bag struts model)... | Andrey Collantes | 11 | 1 |
 | Car shakes when turning Full Lock? | Matthew Sharpe | 3 | 1 |
 | Air suspension | Matthew Sharpe | 4 | 1 |
 | Wheel Fitment | Russell Rohde | 12 | 1 |
 | Allright, Suspension, front wheel bearing and bush/balljoint info p... | Russell Rohde | 2 | 1 |
 | Replacing bushes in perth | Wess McManus | 9 | 1 |
 | Question about lowering and bushes | Mustafa Akgul | 2 | 1 |
 | Supra Torsen LSD installed | Mustafa Akgul | 2 | 1 |
 | G4 shock absorbers ?????? | Paul Mainey | 10 | 1 |
 | Vibration | Dave Rose | 18 | 1 |
 | Brake Warning ( code 43) affected by cold? | Dave Hart | 2 | 1 |
 | Opinions on reco'd steering rack | Braden Murdoch | 4 | 1 |
 | Stock wheels for a day! | Nik Gacomi | 6 | 1 |
 | Supra suspension for V8 | Harry Wijnberg | 4 | 1 |
 | 1991 v8 soarer diff ratio | Peter Nitschke | 2 | 1 |
 | ASI65x troubles | Tom Dodgshun | 1 | 1 |
 | Tyres for Soarer | Joshua Rao | 33 | 2 |
 | Wheel Fit Confirmation | Jose-Antonio Castill | 5 | 1 |
 | Suspension problems please help | Ben Lipman | 12 | 1 |
 | Will these rims fit? | Jose-Antonio Castill | 13 | 1 |
 | Rear Struts Leaking... $600 to fix? SC300 | Dave Cazes | 4 | 1 |
 | Volk GTC | Vinh Bui | 41 | 2 |
 | What is causing this problem??? | Brian Timms | 11 | 1 |
 | SUS Diagnostic codes? | Andrew La'Brooy | 1 | 1 |
 | Refurbished UZZ32 Struts? | Robert Carlyon | 15 | 1 |
 | AirBag Suspension Wont Go Back Up | Rich O'neil | 2 | 1 |
 | Toyota Bilsteins | Jose-Antonio Castill | 14 | 1 |
 | Kumho Slicks | Brian Kelly | 1 | 1 |
 | SPACERS OR NO SPACERS....PROS AND CONS | Andrew Ferres | 23 | 1 |
 | Hopefully the Last Question about TEMS on a TT | Brian Timms | 3 | 1 |
 | Help airbag compressor failed | Daniel Renahan | 5 | 1 |
 | HELP! Can't remove airbags! | David Janiec | 8 | 1 |
 | Worthless to try? (offsets..a |
