  Soarer Central * Suspension * Ride Confort of Lowered Springs Previous Previous    Next Next
Nathan Machin
SC300
Reg: 06-2009
Thursday, February 11, 2010 - 12:16 pm, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Guys
Can anyone tell me if the ride comfort on lowered springs are the same or as smooth as stock shocks or are they firm and rigid like coil overs?
Steve Oleksak
Soarer T
Reg: 07-2009
Thursday, February 11, 2010 - 01:53 pm, by:  Steve Oleksak (Soarin_high) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't think they'd be the same as stock, but it would depend on the springs.
I'm probably getting Kings low springs (not superlow) - Kings told me that the spring rate is 20% stiffer than stock so I'd guess that it's going to be close to stock. At least, closer than riding on the bumpstops like my car is now :-)
Brian Rignall
Reg: 12-2009
Rating:
Votes: 1 (Vote!)
Friday, February 12, 2010 - 09:58 am, by:  Brian Rignall (Cashmere) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It follows very simple principles: the shorter the spring the smaller the length of travel available. Followed by firmer ride as a consequence of stiffer spring rates being required, or else the car would bottom out.
The same applies when moving to bigger wheels and lower profile tyres. Less air and less cushion, coupled with stiffer sidewalls. Many articles and road test show that in most cases when starting from a standard 16" rim, once one goes beyond 18" rim size the ride and handling actually deteriorate - yeah but they wheels look good filling up the arches don't they.
Fashion doesn't always provide an improvement for the vehicle performance and handling.
Nathan Machin
SC300
Reg: 06-2009
Sunday, February 14, 2010 - 09:56 am, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK cool, thats what i was thinking too, just wasnt sure. Thanks Guys
Shan Guansena
soarer GT-T
Reg: 11-2009
Wednesday, May 05, 2010 - 07:43 pm, by:  Shan Guansena (Shan01987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hay nathan, how did u go with the springs? is the ride quality? i was going to get it done but the the guy was like the ride comfort will b going to
Steve Oleksak
Soarer T
Reg: 07-2009
Wednesday, May 05, 2010 - 08:19 pm, by:  Steve Oleksak (Soarin_high) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got the Kings low springs in my car now. It isn't as soft as stock, however it is still comfortable enough to daily drive. It soaks up the jarring bumps that are common with very low/stiff suspension setups. There is also a lot less bodyroll than with stock suspension.
For looks, the King springs lower the front more than the rear compared to stock suspension. Looks much better.
And as far as defects go - I had to get the police to check my car before they would undefect me. With my aftermarket exhaust pulled up closer to the body I had plenty of clearance all around - well over the 100mm required.
Hope this helps.
Shan Guansena
soarer GT-T
Reg: 11-2009
Thursday, May 06, 2010 - 06:22 pm, by:  Shan Guansena (Shan01987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah thanks steve i probelly get it done this w/e will see how we go thanks again.
