Kevin Trac
TryHard 2141.sydney.nsw JZZ30MT, JZZ31AT
Posts: 375 Reg: 10-2006
| It looks like this I took the cover off but I still cant really tell if its an open diff or Torsen.
Matt Petersen
DieHard NA V8
Posts: 637 Reg: 01-2008
| Looks like an open to me. This is a torsen.
Kevin Trac
Posts: 376 Reg: 10-2006
| I know that. Beneath the hands in the picture, I could only have a small view of the gears as it was covered by something. It seemed to look like your picture, but I cant be sure. Seemed to have 2 gears next to each other. Axle code was A01B off the Supra however, which I believe is a Torsen. The diff could have been swapped though |
Kevin Trac
Posts: 377 Reg: 10-2006
| There are also "big cast cooling fins" on the top and bottom of the diff as seen here http://planetsoarer.com/diff/diff.htm |
Matt Sartori
TryHard Western Australia Rx7
Posts: 451 Reg: 08-2008
Kevin Trac wrote on Thursday, December 17, 2009 - 06:17 pm:The diff could have been swapped though
Unlikely. Why would someone downgrade? |
Goo Roo QLD GT Starlet
Posts: 3315 Reg: 07-2005
| hahaha... the money pic gets put up and what do you do ?? Put your bloody hand in the way of the internals which pretty much answers everything ! Get more pics if you want a proper answer mate. |
Ali Saeed
Goo Roo WA V8 Limited
Posts: 1516 Reg: 09-2007
| thats a torsen. the other picture is a TRD |
Kevin Trac
Posts: 378 Reg: 10-2006
| Which 'other' picture? |
Costa Tsimiklis
TryHard Victoria TT 300rwkw
Posts: 307 Reg: 07-2008
| Cant see sh!t with your hands in the way. Photo Fail. Take a better picture and upload it. |
Aiden Cheese
TryHard QLD Soarer jzz30
Posts: 282 Reg: 09-2009
James Harris wrote on Thursday, December 17, 2009 - 06:52 pm:hahaha... the money pic gets put up and what do you do ?? Put your bloody hand in the way of the internals which pretty much answers everything !
thats what i wanted to post
Kevin Trac wrote on Thursday, December 17, 2009 - 08:38 pm:Which 'other' picture?
The one matt posted? |
Matt Sartori
Posts: 453 Reg: 08-2008
Ali Saeed wrote on Thursday, December 17, 2009 - 08:19 pm:the other picture is a TRD
No it's not...TRD are mechanical clutch-type LSD's. The insides completely differ from a torsen. |
Miles Baker
Goo Roo Vic 66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 69 Nova SS Clone, 65 Mustang Fastback, 67 Mustang Convertible, 67 Camaro RS/SS
Posts: 2039 Reg: 08-2005
| Take the photo again but this time use the flash and cut the fingers off your left hand. |
Ali Saeed
Posts: 1522 Reg: 09-2007
| fair enough Matt. |
Goo Roo NSW I have a Cadillac and a Supercharged Manual V8
Posts: 4894 Reg: 07-2005
| Its a T2 Torsen. |
Kevin Trac
Posts: 389 Reg: 10-2006
| It came out of a 96 na auto supra a01b |
Posts: 5726 Reg: 03-2006
| Diff looks offset to me, maybe B03B diff ? |
Kevin Trac
Posts: 398 Reg: 10-2006
| It looks like this when opened up Why cant I see any of the gears like in most other photos? |
Miles Baker
Posts: 2050 Reg: 08-2005
| Turn it a bit |
Posts: 3330 Reg: 07-2005
| oh god.. not again. Kevin - we need to see if it looks like the picture that was posted by Matt, as miles as said, you need to turn it a little then we/you will finally know. |
Kevin Trac
Posts: 400 Reg: 10-2006
| I realised it needed to be turned. Stupid me |
Ali Saeed
Posts: 1593 Reg: 09-2007
| sorry reviving this thread, need to know if this lsd will fit soarer housing. its stated as being out of a jza70, but it looks like the same one as Matt posted
Kevin Trac
Posts: 421 Reg: 10-2006
| Its a Torsen diff! Feels like there is so much more grip while cornering! I recommend this to everyone |
John Stafford
Newbie Qld. Soarer V8
Posts: 4 Reg: 02-2010
| I have bought a 91 V8 that the seller claimed had a Torsen LSD diff but a friend said that it is not LSD because you can spin one wheel without the other back wheel spinning. Is this true? I thought that only under power would the Limited slip kick in. It seems from this attached article that you can't tell from the outside. Thanks for any insights. By the way, he said that it had traction control. How can I know if that is true? I read somewhere that there is a switch for the traction control. If that is right where is it? wanting to learn John |
Blake Gloyn
DieHard manawatu soarer JZZ30 TT
Posts: 564 Reg: 02-2006
| the torsen will spin one wheel without the other if it is jacked up in the air, so fools many into thinking it is an open wheeler. the test is to do a burn out(wheelspin) on tarmac, and see if you leave two black lines or one! traction control has a number of indications. firstly, a second throttle position sensor type thing on the throttle body. also near the strut tower(passenger side), is a small square palstic lid which, when you lift the civer, reveals the relays for ABS and traction control. if the relays for TRC are missing, then it is likely you don't have traction control. |
Posts: 11315 Reg: 11-2004
| An open diff can still make 2 black lines on a consistent surface. Better to test it with one wheel off the bitumen and see if both wheels still spin. |
