  Soarer Central * Suspension * Te37 +20 or +40? Previous Previous    Next Next
Open in new windowArchive through May 24, 2010Ali Saeed25
Warren Moore
JZZ31 2JZ-GE
Reg: 01-2010
Monday, May 24, 2010 - 12:23 am, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
and what about the ball joints and bushes? i dont want to do it if i am risking damaging these..
Victoria (The Nazi State)
Active V8 and the Beast.
Monday, May 24, 2010 - 06:49 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't do it then.
Warren Moore
JZZ31 2JZ-GE
Reg: 01-2010
Monday, May 24, 2010 - 11:01 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im asking dan, are there any aftermarket parts i can get to prevent this?
Soarer 2.5GT-T/GS300
Tuesday, May 25, 2010 - 08:14 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
To fit wheels with the specs you've posted, while getting alignment and drivability in spec you'll need to ditch the stock control arms and get some adjustables in there, and while you're at it you might as well replace the tie rods and ball joints because they will go out (big negative camber at slammed height to fit them wheels = tossing nearly all stock suspension parts for aftermarket).
Search up Ikeya Formula, be warned though, they'll more than likely run you the same money as buying a cheapy 91 twin turbo.
Warren Moore
JZZ31 2JZ-GE
Reg: 01-2010
Wednesday, May 26, 2010 - 03:12 pm, by:  Warren Moore (Warreng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok well first things first, i need height adjustable coils on the front. could someone do an ebay search or maybe a quick search on supra forums to see if there any any decent second hand front coils for sale reasonably priced. im only asking this as I'm not even sure whether any coils can go on the soarer and don't really know whats good and whats not. if its within budget i will get them right away then we will look at getting aftermarket control arms etc. so i can get the wheels fitted.
cheers
Hakan Bayburt
Reg: 11-2009
Friday, July 23, 2010 - 09:14 pm, by:  Hakan Bayburt (Suprahb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry to hijack the thread, but the first soarer in this thread is awesome, whats the name of the wing?
David Watt
Saturday, March 10, 2012 - 02:02 pm, by:  David Watt (David_w) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that wing is Wise
