  Soarer Central * Suspension * Steering Wheel Off Center to Stay Straight (After Accident) Previous Previous    Next Next
Matthew Tai
Friday, March 05, 2010 - 08:28 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All,
My cars previously been hit in the rear left, and its thrown the alignment out.
I've taken it to be realigned (stock specs) and the car now only goes straight if the steering wheel is about 10-15 degrees to the right.
It was previously aligned to keep the steering wheel straight to go straight but I will then get clunks in the rear when going over bumps.
Any idea what I have to get replaced/fixed to get things back to normal?
Thanks in advance,
Matt
Ben Lipman
Friday, March 05, 2010 - 09:36 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Get the suspension place to tell you what is broken or bent and then fix it.
Otherwise you can straighten the steering wheel by adjusting your tie rod ends assuming you have enough adjustment left.
Saturday, March 06, 2010 - 11:14 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Clunking in the rear could be all sorts of things from a stuffed shock to a loose swaybar.
If the car is crabbing and is requiring excessive toe adjust at the front to correct, then the chassis and/or suspension components are damaged and need to be repaired/replaced
If you wheel aligner didn't get your wheel straight and gave you no explanation why, then he is a cowboy and you shouldn't go back to him. They should start by locking the steering wheel in the straight ahead position, and adjust the tierods from there.
If there isn't sufficient adjustment left in your tierods, you can also re-align the wheel by removing it and turning it on the splines. This will throw your indicator auto-off out too, unless you also adjust it. Really much better to adjust the tierods if you can.
Matthew Tai
Saturday, March 06, 2010 - 12:08 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys: I've had new shocks put in and the rear checked over so I'm unsure wether the aligner either tightened things up or the realignment made the clunking go away, but either case it is gone now after the realignment.
The aligner did say that the steering wheel would be off if i wished to align to stock specs and straitening it would give the rear left wheel some more camber or something i think...i cant exactly remember :-) i'll take it down to the susp. shop and see what happens.
Ben Lipman
Saturday, March 06, 2010 - 09:26 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ask your aligner what your thrust angel is.
Thrust angle= Ummm. How to explain this...it is the angle of the entire rear axle assembly relative to the centre line of the chassis.
It is important because it is possible to have both rear wheels parrallel, same camber, etc but the whole lot at an angle to the chassis meaning excess adjustments at the front end to get the car to drive straight.
This is more common in solid rear axle cars, but could be a possibility if yours has copped a hit.
I just do not understand why getting the steering wheel straight affects the rear camber.
Matt Sartori
Rx7
Reg: 08-2008
Sunday, March 07, 2010 - 12:04 am, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Take off your steeringwheel and put it straight. Instant and quick easy fix!
note: probably not the greatest idea
Matthew Tai
Sunday, March 07, 2010 - 12:09 am, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben: Its possible my brain could have just made the camber bit up! My memory is fuzzy on the reason but he did give me one and it sounded reasonable at the time lol.
I'm not sure how bad the hit was since it was done by the previous owner but i'll have to take it to a suspension specialist. I actually had Niall look over my suspension when i had him install my shocks and he couldn't figure anything wrong (or the clunking for the matter) so i'm not sure how obscure the problem could be...
Matt: no :-)
