  Soarer Central * Suspension * Melb: Need help to get a spring back in.... Previous Previous    Next Next
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Tuesday, March 23, 2010 - 02:22 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As topic, One of my springs has come out of the seat.. i have no idea how ot get it back in, wheather its a quick job or a long job. I really need new springs but I can't afford that.
Anyway .. is there anyone in melbourne that can help me that isnl;t going to charge a fortune? Anyone wanna help me out for beer?
Wednesday, March 24, 2010 - 06:43 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Springs as in suspension springs? How the hell did that happen? Is it front or rear? Airbag or gas shock? More info...
Springs don't usually "wear out" and they are under a fair amount of compression even when they have no weight on them, so really shouldn't pop out - unless they have been cut or heated to lower the car, in which case they are ruined and junk, or if the rubber in the hats has perished it could perhaps cause an issue like this, though you would notice clunking and banging long before it jumped out.
I have no clue as to what other problems in an airbag strut could cause this, but again I would think its an indicator of terminal failure. If its happened once, it will happen again.
Matchy Loi
GTT
Wednesday, March 24, 2010 - 09:11 am, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a spring compressor you could borrow, it's not that hard to do, but I think you should find the exact problem first. I've even got some standard TT springs if they fit.
Jack car up, remove wheel, undo sway bar (allen key).
Try to compress spring, if it doesn't fit, take the shock off the car and try again (note at this point you may need a massive vice.)
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Wednesday, March 24, 2010 - 04:18 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matchy, gonna send you a mail mate.
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Wednesday, March 24, 2010 - 04:22 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When i bought the car I was told it was lowered, unfortunatly i never checked and have found out the springs (rear) were cut.
She is a 31 and has had air bags removed.
My Pass/rear srping have gone around the seat so i need to replace them eventually with a set of real lowered springs ,.. just running real low on cash atm
Thursday, March 25, 2010 - 06:44 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bugger!
Springs are pretty cheap especially as you only need two of them. Should be able to get a pair for around $100 - $150 depending on brand etc. Fitting is easy especially the rears, and you already have the offer of a compressor. I just have a cheap set I bought from Supercheap for something like $40 and they work fine.
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Thursday, March 25, 2010 - 10:34 am, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers foir the... is it really just an allen key holding the sway bar on ... trippy
Thursday, March 25, 2010 - 01:23 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No, its a nut on a balljoint, but you can hold the balljoint still while you undo the nut with an allen key. BUT you don't need to disconnect the swaybar linkage to remove and replace the rear shocks.
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Friday, March 26, 2010 - 09:47 am, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matchy I haven;t heard anythign from you, I've sebnt you an email.
You can call me on 0425 885 042 or email me
tpja2005@optusnet.com.au
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Sunday, March 28, 2010 - 08:55 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone else got a srping compressor?
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Friday, April 02, 2010 - 09:15 am, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can hire them from Kennards.
