  Soarer Central * Suspension * Rear suspension and diff bushes Previous Previous    Next Next
Nik Peacock
Tasmania
V8 GTL
Reg: 05-2006
Friday, April 30, 2010 - 02:50 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can anyone point me in the right direction for a complete set of rear bushes, I.E. upper and lower arms, toe arm, trailing arm, diff mounts, cradle mounts. Want them in poly and yes I know the rubber one are more comfortable, don't squeek etc.... looking at the poly because I want more of a hardcore setup.
Already have poly in the front and to be honest I haven't had a problem, no squeeks, dont find them too harsh.
Would like to be able to source them all from the same place if possible
Spencer Cameron
JZZ30 (converted Manual)
Reg: 04-2008
Friday, April 30, 2010 - 05:59 pm, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think Dave Cazes still deals in this stuff. I doubt the prices in the thread below are still relevant, but I'd send him a PM if I were you.
http://soarercentral.com/sc-forum/messages/30604/287611.html
Nik Peacock
Tasmania
V8 GTL
Reg: 05-2006
Monday, May 03, 2010 - 08:55 am, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I tried Dave but he is flat out with his new job atm
Spencer Cameron
Reg: 04-2008
Monday, May 03, 2010 - 10:23 am, by:  Spencer Cameron (Switchio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well, in that case, u can find the part numbers for any of the bushes you ned through this site:
http://www.fulcrumsuspensions.com.au/products.html
and you can order them though a bunch of different companies, one of which being these guys:
but if memory serves, even supercheap can order them in so, its just up to has the lowest price i guess.
Costa Tsimiklis
386.2 rwkw Soon T51R or GT4094 :-O
Reg: 07-2008
Friday, May 07, 2010 - 08:15 pm, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Nik,
I'm about to get a set myself for the street/track car so I will do some research and let you know.
I was thinking of providing a change over service so people can get them installed without being ripped off by local mechanics.
I've installed the steering bushes and that made a huge difference to the steering response - especially with a smaller sport wheel!
Nik Peacock
Tasmania
V8 GTL
Reg: 05-2006
Monday, May 10, 2010 - 12:09 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I ended up getting upper and lower bushes from Neil, all the suspension places only did uppers and nothing else, Neil may even have a solution for the front diff mounts using some modified front bushes, will let you know how it goes.
As for the trailing arm and toe I may just get the adjustable ones from Megan racing as I'm thinking about their engine and transmission mounts
Phil Gibson
Monday, May 10, 2010 - 12:23 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes the Superpro (Fulcrum) front LCA bushes can be cut and are the perfect size for the front diff mounts
Superpro also do the diff subframe bushes
