  Soarer Central * Suspension * Strut Bar... Previous Previous    Next Next
Natasha D'Abreo
Reg: 10-2009
Friday, May 14, 2010 - 12:17 pm, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I recently bought a strut bar for my car. The bloke i bought it from said it didnt fit his V8.
I tried getting the tems caps off, but the bolts were to tight. We tried with a 14mm socket that we purchased from supercheap, and the adapter broke!
But anyway, I can see a wire connected to the cap, does anyone know if i would be able to put the strut bar on? And also do they make any difference with the handling on the car? Alot of people say it dosnt. I like how they look anyway.
Mines black at the moment, so I was going to sand it back and spray over it.
I bought a chrome spray that is heat resistant for up to 500degrees, they also had a metallic red spray which was simillar to my car. Not sure which colour i will be spraying it though.
Nik Peacock
Tasmania
V8 GTL
Reg: 05-2006
Friday, May 14, 2010 - 12:39 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It wont fit with the tems, although I have seen some modified/custom ones done to fit with the tems. I have one on my v8 with coilovers and I certainly noticed the difference, turn in was improved heaps, didn't understeer any where near as much when pushing it hard
Scott Wilkes
Tasmania
92 TT Factory Manual, 70 HG GTS Monaro
Reg: 10-2008
Friday, May 14, 2010 - 03:43 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
they do work with TT tems, remove the tems covers and it bolts straight down, i have a strut brace on my tems equipped TT soarer
Natasha D'Abreo
Reg: 10-2009
Friday, May 14, 2010 - 04:11 pm, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So when I take off those tems caps, what do I do with that wire thats attatched? is it meant for something?
Friday, May 14, 2010 - 04:26 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That wire controls the TEMS suspension and will need to be connected back on.
Ali Saeed
Friday, May 14, 2010 - 05:46 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i thought about getting one, but i dont think i can cause of my airbag suspension :-(
Murray Lund
Friday, May 14, 2010 - 08:59 pm, by:  Murray Lund (Murray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Natasha,
Its an interesting read to search 'strut brace' on SC. Most of the long term and respected Soarer experts on here say that strut braces only work on McPherson strut suspension (which Soarers don't have). There's always a lively discussion when the subject comes up. Suspect its a variant of the long running form v. function debate - what looks good as opposed to what works good e.g. dished wheels v. proper Soarer offset, stretched tyres v. correct fitting, 19/20" wheels with rough ride anywhere off the expressway v. 17/18" wheels and a degree of ride comfort. I suppose at the end of the day a strut brace does no harm. Good luck with your fitting.
Damian Ware
UZZ32
Friday, May 14, 2010 - 11:10 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/cgi-bin/sc-forum/search.cgi
Have a read but if well designed then they are effective at chassi stiffening and the soarer chassi like most 90's Toyotas have a lot of flex.
Natasha D'Abreo
Reg: 10-2009
Wednesday, May 26, 2010 - 10:17 am, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks
