  Soarer Central * Suspension * Rims and Tyres Previous Previous    Next Next
Richard Luong
SC400 V8
Reg: 03-2010
Thursday, August 12, 2010 - 12:09 am, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm looking into geting:
Rim:
Front 19/8
Rear: 19/9.5
Tyres:
Front: 235/30/19
Rear: 265/30/19
Are my numbers right or am I little bit off
So would the rears fit in nicely or am I going to need the guards rolled or will i get away with stretched tyres?
Also what are reasonably priced tyres for 19's?
Richard Luong
SC400 V8
Reg: 03-2010
Thursday, August 12, 2010 - 12:22 am, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
don't worry about this post found thread sorry
Marc Hoffmann
Reg: 07-2009
Thursday, August 12, 2010 - 12:23 am, by:  Marc Hoffmann (Rushed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my wheels are the same sizes (if you remember)
I had massive rubbing with 265's, went to 255's problem solved (although my rear guards are bent up a bit as a measure during the reign of the rubbing 265's.)
I payed, $520 for a pair of 255's a few months ago, although that said they are not great... i'dd love to find a good cost/grip balance tires so I might be able to launch with some boost on.
Ali Saeed
Thursday, August 12, 2010 - 02:39 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its all dependent on your offset anyway
