  Soarer Central * Suspension * Power steering gone heavy Previous Previous    Next Next
Narvey Vilaythong
soarer tt and 3T-GTE corona liftback
Reg: 09-2009
Monday, August 30, 2010 - 06:53 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys, some of you would know that my car was on defect and many things had to be done for it to get it back on the road. One of them was a leaking pinnion seal. What happen was i sent my car in to get the seal replace, along with the upper control arms bushes, front sway bar bushes and the steering rack bushes. I got superpro fitted. They guys said that they replaced some seals and o rings in the rack.
when i got my car back, i noticed that the steering was more responsive in a way but what i noticed most was it was more heavy then before. I thought ok, ill live with it...
2 Weeks later (now)
I noticed that the steering got more heavy and when I turned the steering wheel, it goes soft then heavy. Very Very similer to having air in the system. I have checked all levels of the PS and everything seems to be fine...
Did they stuff up something? Or is my pump on the way out? (pump looks to be recon when i got it, no leaks and came with new hoses)
Tuesday, August 31, 2010 - 08:11 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Superpro = poly right? Poly bushes are the wrong thing to run in a Soarer - stick with rubber bushes. Not sure if that's why your steering is going funny, but pretty much everyone on here who has tried plastic bushes in a Soarer has regretted it.
Damian Ware
UZZ32
Tuesday, August 31, 2010 - 08:22 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They probably didn't plug the solenoid back in which will make the steering heavy as it has nearly no power assist.
Not sure if this relates to all your problems but it explains the first issue.
Narvey Vilaythong
Reg: 09-2009
Tuesday, August 31, 2010 - 02:26 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, i went with superpro as i had no choice at the time due to defect and money and i needed the car back on the road asap. I now have VFT front endbushes sitting at my desks waiting to be put in soon.
Damian Ware wrote on Tuesday, August 31, 2010 - 08:22 am:
where is this solenoid located?
Damian Ware
UZZ32
Wednesday, September 01, 2010 - 07:47 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Narvey Vilaythong wrote on Tuesday, August 31, 2010 - 02:26 pm:
Cant remember of the top of my head but you can see it from the top, just shine a light down each side and look along the rack.
Tom Richards
Wednesday, September 01, 2010 - 09:13 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is an elect plug on the chassis on the inside of the RHS front wheel well. If it is disconnected steering will be heavy.
Trent Linnell
Reg: 10-2007
Wednesday, September 01, 2010 - 09:04 pm, by:  Trent Linnell (Tlinnell) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can honestly say it has nothing to do with your bushes. I have Superpro Bushes and don't have a problem with them.
Md Adib Bahzi Majid
Brunei
UZZ31 Soarer V8 Limited
Reg: 09-2008
Thursday, June 09, 2011 - 11:14 pm, by:  Md Adib Bahzi Majid (Adeep) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tom, can you take a photo and attach it here for the exact location of the electrical plug on the chassis on the inside of the RHS front wheel? I'm afraid mine is caused by this too after the mechanic replaced with new power steering and alternator.
Paul Fitzsimmons
12/96 vvti single
Saturday, June 11, 2011 - 04:47 pm, by:  Paul Fitzsimmons (Oztif) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/285/284108.html?1269079677#POST409297
