  Soarer Central * Suspension * Spacers for LCA bush? Previous Previous    Next Next
Narvey Vilaythong
soarer tt and 3T-GTE corona liftback
Reg: 09-2009
Sunday, September 05, 2010 - 08:51 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys, I have bought myself a set of front lower control arm bushes (VFT) for my JZZ30. I currently have nolothane in my from the previous owner. In HPI, issue no.72, they did a thing on soarer bushes and they said that you need a bushing spacer if using rubber bushes. Is this true? and if so, how many do i need and what is the part number?
Costa Tsimiklis
386.2 rwkw Soon T51R or GT4094 :-O
Reg: 07-2008
Sunday, September 05, 2010 - 11:51 pm, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is this for the front LCA? there is a factory bush spacer on one of the bushes.
www.toyodiy.com for the complete Toyota EPC online will help you find it :-)
Tom Richards
Monday, September 06, 2010 - 07:51 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is a rubber spacer that fits between the arm and the chassis so that on braking etc the arm doesnt go forward and hit the chassis. from castle hill toyota they were ~$15 ea from memory
V35
Monday, September 06, 2010 - 09:58 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is the part number for the spacers:
48657- 24020
Narvey Vilaythong
Reg: 09-2009
Monday, September 06, 2010 - 10:44 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks guys, how many do i need?
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Monday, September 06, 2010 - 10:50 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check to see if your have them first Narvey..
Narvey Vilaythong
Reg: 09-2009
Tuesday, September 07, 2010 - 11:34 am, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin Camilleri wrote on Monday, September 06, 2010 - 10:50 pm:
I don't, because my car is fitted with nolothane all round on the front lower control arms.
Tom Richards
Tuesday, September 07, 2010 - 03:02 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you need 2, one for each side.
from memory, the "knobbed side " goes to the LCA.
Costa Tsimiklis
Reg: 07-2008
Tuesday, September 07, 2010 - 08:07 pm, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tom, you are correct, its the front bush, goes on the inner side.
Picture:
http://www.toyodiy.com/parts/diag_2q0TBD.png
Narvey Vilaythong
Reg: 09-2009
Sunday, October 24, 2010 - 04:11 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys, while i was down there, i notices the front bushes still had a bit of space left, would it be safe to put spacers on front ones as well to help reduce as much movement?
