Wednesday, March 09, 2011 - 10:26 am, by: Chris Lock(Sledge)
From other thread: I disconnected battery, connected controller with loom, reconnected battery, and all i get is a warning telling me to 'check air suspension' Car does not move up or down either with the controller or the height switch. I got 2 controllers, and 2 looms, and it does the same thing with everything.. Remove the controller and the suspension works as it should. The controller lights up, and seems to work, but does not effect the car..
Wednesday, March 09, 2011 - 10:42 am, by: Chris Lock(Sledge)
So, i tried: controller 1 with loom 1 controller 2 with loom 1 controller 1 with loom 2 controller 2 with loom 2 All doing the same thing.. When the wife brought home her car, it tried 1 of the controllers in her car and exactly the same thing happened.. Didn't test further as i assumed the rest would be the same as well.
Wednesday, March 09, 2011 - 02:48 pm, by: Chris Lock(Sledge)
It was lowered manually following this guide: http://soarercentral.com/sc-forum/messages/67/468.html?1099559368 the normal 'low' setting is now my high setting, and putting it into low mode drops it a little more.. It is currently in the 'high' setting which is where i tried the controller..
Wednesday, March 09, 2011 - 03:29 pm, by: Chris Lock(Sledge)
Thanks cameron, where did you get the looms from? Any markings on them that may help identify them? On these ones i have a datasystems serial number sticker And H-076A written in texta
Wednesday, March 09, 2011 - 03:45 pm, by: Cameron Cuddihy(Cam)
My controller is different to the one you have, but I'm pretty sure that it will be the same problem. There are heaps of different harness' for different controllers and also for different vehicles, but there will be a specific one for that controller that is for a UZZ31. If you bought it off Rob see if he can send you some different harness'
Wednesday, March 09, 2011 - 04:09 pm, by: Chris Lock(Sledge)
hrmm can't find an email on datasystems website to ask which harness i need.. Though i sent one to Elite Auto Style to see if they can help with model number..
Sunday, March 13, 2011 - 10:27 am, by: Chris Lock(Sledge)
Anyone in SA got one of these controllers that i can come and test these with your loom etc? Or someone that doesn't have a controller at all, can i test in your car? Cheers
Tuesday, March 22, 2011 - 08:06 pm, by: Chris Lock(Sledge)
Ok, Robert has sent me a ASG616A to test things out, and it seems to work fine, but i can't figure out how to use it Does anyone have any english instructions at all? Cheers
