  Soarer Central * Suspension * Rubber top mount for Tein Coilovers Previous Previous    Next Next
Edison Koh
JZZ30 VVTi
Reg: 08-2010
Friday, March 11, 2011 - 09:58 am, by:  Edison Koh (Reiven) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well i fitted a set of coilovers on my soarer.
The feeling was great especially while cruising on flat roads and cornering. However, I keep getting noises in the rear when travelling over tiny speed hump stripes and rough roads. It sounds like thudding against wood.
I ended up setting up my boot with eggcarton foam but it was pointless.
Could it be the pillow top mount bearings which are getting on age? Thinking about replacing the top mounts with rubber ones if possible.
I certainly hope it isnt any of the rear bushes screwing up. Reckon its a labour intensive repair for those.
Appreciate any feedback!
David Ormsby
GTTL
Reg: 02-2008
Friday, March 11, 2011 - 06:32 pm, by:  David Ormsby (Phoenix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Worn pillow ball mounts on Tein coilovers is very common. All four on a set I picked up were noisy, although the condition of the rest of the set was like new.
I managed to fit some factory strut tops on the front although a bit of modification is required due to the different diameter springs. On the rear I used another trick to stop the noise, take off the top nut and fit a rubber and a steel washer before putting the nut back on - essentially locking the ball into the housing.
You could try the washer trick on all of them to check whether it is the pillow balls making the noise.
New pillow ball mounts were NZ$125 each (just the pillow ball pieces not the whole strut top) plus fitting costs.
Edison Koh
JZZ30 VVTi
Reg: 08-2010
Friday, March 11, 2011 - 11:31 pm, by:  Edison Koh (Reiven) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks David!
I'll look into that option.
David Ormsby
GTTL
Reg: 02-2008
Monday, March 14, 2011 - 03:57 pm, by:  David Ormsby (Phoenix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problem, one other thing to eliminate from the equation is checking that the adjusting collars on the struts are tight.
Good luck and let us know how you get on.
