Wednesday, April 13, 2011 - 04:58 pm, by: Thomas Holdaway(Tnt)
Hi all, I'm wanting to get my Soarer sitting a bit lower so I enquired at Mag & Turbo and they said a 25mm drop front and back would look good. However I'm not too sure.
At the moment it's factory suspension with 265/35/18's on the back and 235/40/18's on the front. At the back the guard is 30mm from the top of the rear tyre, whereas at the front the guard is 55mm from the top of the front tyre.
The look I'm going for is the guard sitting quite close to the tyre so I'd be quite happy with the rear 25mm drop. I'm just wondering if I should drop the front a bit more (like 45mm)?
Also wondering if this is normal for UZZ30's to sit a lot higher at the front?
Thursday, April 14, 2011 - 04:40 pm, by: Mike Beck(Gold_40gt)
Cobra springs, hmmm sounds like one to avoid.
Supra springs can also work, I used a full suspension setup from a JZA80 in one of my Soarers.
That means you could use an H&R German spring kit for the Supra, it's rated at 1" lowering, but as far as I know supra springs are already lower than soarer ones as stock.
