  Soarer Central * Suspension * TRD LSD instructions Previous Previous    Next Next
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Tuesday, July 19, 2011 - 08:54 am, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone have some instructions on how to change a 2 way to 1.5?
Cheers Nik
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Tuesday, July 19, 2011 - 02:05 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone? was hoping to install this weekend
Paul Mainey
Twin Turbo V8
Tuesday, July 19, 2011 - 04:49 pm, by:  Paul Mainey (Gttv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As far as i know mate it's not possible. They are a 2 way only. There has been some discussion over the years on the supra forums about the ability to swap between the two.
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Tuesday, July 19, 2011 - 07:04 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From what I've been told by a very reputable member that I bought it off it is a very easy process, I'm just waiting for instructions from him but he is away for a few days, so was hoping that someone here might know the process so I can install this bad boy this weekend
Matt Sartori
Rx7
Reg: 08-2008
Tuesday, July 19, 2011 - 08:13 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Mainey wrote on Tuesday, July 19, 2011 - 04:49 pm:
Most clutch pack diffs are capable of being swapped between 2-way and 1-way...
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Tuesday, July 19, 2011 - 11:13 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe that Soarer TRD LSD's are incorrectly stated as 1.5/2.0 on just about all websites. I'll find the link to this, stand by.
Nathan Richardson
N.T.
Tuesday, July 19, 2011 - 11:51 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can't seem to find the link on my phone at the moment, but it is something to do with poor translation off the TRD website that has caused the issue. (all second hand info by the way).
As has been said there is a few posts in the Supra forums with this issue and I think the Soarer is the same part number.
Matt, I would like to know how to switch "most" LSD's between 1.5 - 2.0!?!?
A how to should be not too much to ask then?
Cheers.
Sorry Matt, just re-read your post but I'm still not sure what you are getting at with regards to this topic?
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Wednesday, July 20, 2011 - 08:18 am, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll post up a how to when I find out
Matt Sartori
Rx7
Reg: 08-2008
Wednesday, July 20, 2011 - 10:49 am, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nathan Richardson wrote on Tuesday, July 19, 2011 - 11:51 pm:
I never said MOST, i said most CLUTCH PACK diffs, Also knows as mechanical diffs, you know Kaaz, cusoc, TRD, etc..
Kaaz and Cusco can, why wouldn't TRD be able to? They're essentially all the same setup, just different brands, no?
I'm just saying i don't see any reason why you wouldn't be able to?
Blake Gloyn
manawatu
soarer JZZ30 TT
Thursday, July 21, 2011 - 07:17 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the trd diff can't be swapped from 2 way to 1.5 way, according to the diff shop that set mine up.
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Thursday, July 21, 2011 - 09:10 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blake, what's the 2way like on the street?
Blake Gloyn
manawatu
soarer JZZ30 TT
Thursday, July 21, 2011 - 09:37 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Perfectly driveable. you get a tiny little bit of diff clunk/tire noise when turning at v slow speeds on gravel/tarseal, but apart from that, quite livable. i would have prefered a 1.5way, but apparently they(TRD) don't make them anymore.
